I am getting a cyclic redundancy error when trying to install this Netgear Wireless adapter software. I do not believe the software is corrupted, as it was installed previously, but for some reason, after a couple years of use, the wireless adapter seemed to stop working and the adaptor was not being detected. Therefore, I de-installed the software and am trying to re-install it. Any idea why I'm getting this error message?
SOURCE: I have a wireless netgear
You first need to install the driver. You can download it here:
http://kbserver.netgear.com/products/wg111t.asp (it should have came with your adaptor)
You must also have a wireless router available for this to work, or in an area that has WiFi available.
SOURCE: Netgear Wireless USB Adapter wg111t; installation
need help to install the product to my computer
SOURCE: ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
SOURCE: netgear wireless adapter wg111t will not work work
It's impossible that the wireless router cannot detect your wireless adapter wg111t.
You try to test another one if still have a problem connecting with your wireless router.
If that router can see another wireless network available then maybe your Netgear wireless adapter have a problem incomplete installation or the wireless device is defective.
I have encounter like this before so maybe it's the same with.
Hope my tip will help you a lot.
Please rate me.
Thank you.
Testimonial: "thank you yboyandrei for the quick fix solution!!!"
SOURCE: Netgear WG111 USB adaptor does not work
-- check the device manager of your computer
-- for win xp - go to right click on my computer - manage - computer management - device manager - on the right hand side that the netgear adapter is listed under network adapters or other devices
-- check the status that its working properly
-- then upgrade the latest drivers ...
-- follow the link ::
http://kb.netgear.com/app/products/model/a_id/2556
and try to connect ..
The software initiates as if it is going to install, but then about 30 seconds into it, it stops and gives this error. Specifically it says: Feature: CU App
Component: CU CPL
File: D:\utility\data2.cab
Error: Data Error (cyclic redundancy check)
Any ideas on what I can try or check?
