20 Most Recent NetGear WG111V2 Wireless Adapter Questions & Answers
HI! this is Alex Walker expert to fix this issue for you call +1(518)348-9393 Thank You
NetGear WG111V2... | Answered on Jul 03, 2017
LOST WIFI SECURITY KEY WORD
If you have lost your WEP/WAP wifi key phrase there is no way to recover it except go into the router administration settings and see if it is in plain text there. If not then you will have to make up a new key phase and apply it to ALL your connected devices.
In future, write the key phrase down on a piece of tape and apply it to the bottom of your router. You can use a hint instead of the actual phrase.
I use the memo function of my cell phone to keep all my passwords and keys.
NetGear WG111V2... | Answered on Apr 08, 2014
click start control panel administration tools computer management device manager scroll to network adapters you might see a yellow question ? exclamation ! mark or a red X
the driver will need to be updated right click to update driver
if you dont have the disk with the driver you will need to download one
http://download.cnet.com/netgear-wg311v3-802-11g/3000-2112_4-78104.html
hope this helps you
NetGear WG111V2... | Answered on Apr 09, 2012
Here is a step-by-step article which describes how to install the wireless adapter in Ubunty Edgy.
The download link for the zip file is outdated, but you get it from here.
You don't have to register, there is a link saying "Skip Registration" and the download will start.
Let me know if you have any problems.
NetGear WG111V2... | Answered on Apr 05, 2012
This is a USB wireless antenna. If you install this on your computer you will have the ability to access the internet without having to plug into a LAN (Local Area Network). Now, this does not mean that you get free internet, unless one of you neighbors is broadcasting a wireless signal and has left it open for everyone to Bogart on. It just gives you the ability to wirelessly connect to any wireless network that you have authorization to access. Your own for instance. Set up in your own home. The coffee shop, the bookstore, mcdonalds, etc.
Here is a link for the support driver if you need it. Don't forget to rate this solution high for me please. http://kb.netgear.com/app/answers/detail/a_id/713
NetGear WG111V2... | Answered on Jan 25, 2011
You will need to install the drivers for the wireless adaptor. The flashing blue light simply indicates that there is activity (communications) with a wireless access point.
You can find the drivers for it here;
http://netgeardownload.registria.com/single_page_registration?product[sku]=WG111v2&download_url=ftp://downloads.netgear.com/files/WG111v2_v4.0.0.zip
~KenjiFox
NetGear WG111V2... | Answered on Jan 07, 2011
  • log in to the netgear router's interface using www.routerlogin.com
  • username- admin , password : password
  • Click on wireless settings under setup . ( 3rd option from the top )
  • Under the security options .
  • U can find ur security passphrase to connect with netgear wireless.
In case of further assistance , do revert back
NetGear WG111V2... | Answered on Aug 18, 2010
Hello Sir,
strage thing. Try to do following things:
1. Switch off computer
2. Plug out device
3. wait 45 seconds
4. switch on computer again, log in to the system
5. plug in the device BUT in different USB port!!!
PS: you may also check in: Right click on My computer icon -> Manager -> Device manager if this device is regocnized by system or it has "?" icon.
Cheers,
Mike
NetGear WG111V2... | Answered on May 08, 2010
HI,
Please download the reaquired software from the below link:
http://www.ziddu.com/download/7080987/wg111v2_3_4_0.zip.html
Install the adapter using these drivers to resolve the issue.
Regards
Anand
NetGear WG111V2... | Answered on Mar 08, 2010
Your wireless adapter, the one in your laptop, the laptop we know nothing about because... well who knows why you would withhold that vital bit of information, all I can do is speculate, and speculation is usually counter-productive, and I answer questions on this board to be productive, so what I am getting around to say is that the aforementioned wireless adapter, the one in your laptop, needs to be 5 GHz capable. I would know this if you cared to tell us what make and model of laptop you have as opposed to just the router which we know is 5 GHz capable because you told us. Of course, by posting in the Wireless Network Adapter forum, you can assume that we can look at your post and inherently know all the information about your problem because we are "experts".
NetGear WG... | Answered on Apr 23, 2014
This is a simple, USB based network interface card (NIC). There's little to be changed as it is built with tiny surface mount devices that can not dissipate heat nearly as well standard through hole components can. Boosting voltages, etc will only shorten the life of the device.
Locating the NIC closer to the WiFi source will improve throughput of the device. If this is not possible, increasing the height or physically reorienting it may provide some gain. The easiest way to do this is to purchase a simple USB cable that will connect to the computer's USB poert and accept the WNA1100 on the other. These cables are often available at electronics and computer stores in 3, 6 and 12 or more foot lengths for under $20 (and significantly less online). I would not purchase or connect lengths greater than 15 feet, as this is the maximum length supported by the USB standard without some sort of active repeater built in to the receiving end. By placing the WNA1100 at the end of the cable, you are free to orient it in the best position to maximize capture of the WiFi signal, regardless of the position or location of the computer.
NetGear WG... | Answered on May 14, 2012
NetGear WG111V2 Wireless Adapter Logo
14 questions posted
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
WG NetGear
  • WG NetGear
Most Popular Question
get passphrase open netgear wireless
  • Computers & Internet
