20 Most Recent
Linksys WUSB300N Wireless Adapter Questions & Answers
Im using a friends computer
What operating system are you using?
Here is a link to the site with info and drivers are on the right of the page.
http://www.linksysbycisco.com/UK/en/products/WUSB300N
If my answered help give me four thumbs as thanks!!
When my wusb300n is plugged in to my computer it
the reason it does that is because your pc is attempting to boot from usb there is a way to solve that issue without having to disconnect the wusb and here is how...restart your pc as soon as it comes on enter the bios setup by pressing the button it tells you to usally esc or f1 f2 or 10 once you enter the bios setup search for the boot section and disable boot from usb or move it down on the order which should be set to number 1 cd/dvd number 2 hard disk and so on.. then after you have completed this save and exit it then should reboot and have no problems with the wusb
Computor running very very slow
There might be several reasons for the performance to go down. Three main things which usually contributes to your PC performance is Size of the RAM larger it is faster it will be. Processor speed more it is shows better performance finally free space on the hard drive (Very Important) it can be compared to a person carry 10 pounds can run faster than person carrying 100 pounds. Less the free space worst the performance.
Having said that i would suggest you to follow some steps suggested in the link below,
http://www.fixya.com/support/r6910202-speed_up_pc
I hope it helps....good luck
Usb dowonlod
Hi Sir/Madam;
Here is the source link to download the driver/software for your Linksys -WUSB300 N wireless adapter.
Click here :
Linksys
Thank you for using Fixya.
How do I uninstall Linksys
Assuming you are using mirosoft windows, open the control, open "add or Remove Programs" select the linksys software, and click on remove. Then restart the computer.
My wireless adapter drops the
Try using a different channel, move your antenna's around keeping in mind reflective and blocking walls/metal shelves/trees/etc. You may have a great signal but there are many other issues that can plague a wireless signal while it still shows strong from your adapter/driver.
Use one of the war driving or basic spectrum analyzers to try to determine which channels are least congested in your area.
I've been reformated my notebook and install the
Have you installed the appropriate drivers?
Okay here you go:
goto www.linksys.com
search for the drivers and see whether this device is compatible with windows 7. When you find the drivers download and install them.
I hoped that you did not install any drivers for this device previously and if you even did install first uninstall those drivers and then re-install the freshly downloaded drivers.
Hope this works!
Stops working
Try to update the driver of your adapter or try installing it on another computer.
I cant connect using my linksys wireless
- hard wire the laptop to the router, which reestablishes the connection.
- set the connection to be wireless
- follow the prompts and you will soon be wireless again
I have a Belkin wireless G Router and have just
Connection and signal strength depends upon the router. Just go through the settings on the wireless router, try changing the wireless channels.And also change the wireless mode on the router to 802.11g.This should be the compatible mode for your wireless adapter. to do this first connect the router with the help of an ethernet cable .Please follow the below steps:
1)Using your Internet browser, you can access the Router’s Web-Based
Advanced User Interface. In your browser, type “192.168.2.1” (you do
not need to type in anything else such as “http://” or “www”). Then
press the “Enter” key.
2)
You will see the Router’s home page in your browser window. The
home page is visible to any user who wants to see it. To make any
changes to the Router’s settings, you have to log in. Clicking the
“Login” button or clicking on any one of the links on the home page
will take you to the login screen. The Router ships with no password
entered. In the login screen, leave the password blank and click the
“Submit” button to log in.
3)
Clicking on the header of the “Wireless” tab will take you to the
“Wireless” header page. From this page, the Router’s wireless radio
can be enabled or disabled (the default setting is enabled). Under the
“Wireless” tab, there are links that allow you to make changes to the
wireless network settings.
4)
Your Router can operate in three different wireless modes:
“g and b”, “g only”, and “b only”.
5)
Change the wireless channel to 9 or 11
Click on save changes once you have done this
This should work,if it doesnt work let us know the exact problem in detail.
