Laptop used to display to external HP screen , after a couple of days not used, it won't display on thei scren now - my lenovo care was empty until I downloaded and re-installed , but now when I open care / device config/mange other devices , it goes straight to the windows control panel. is this due to me trying to clean up the PC and inadvertantly removing the care package ?
SOURCE: I have a Lenovo 3000
What about removing the hard drive from the laptop and put it into sata box, to be USB external drive.
And then get out your important data, and format the hard disk.
and try again to boot???
If it doesn't work , try to replace the memory it might be the problem with the memory.
SOURCE: Problem with integrated webcan Lenovo 3000 N100 notebook
Buy external webcam; troubleshoot this problem was westing our time.
SOURCE: A problem regarding bluetooth
You need to install the bluetooth software, if you have a disk, install from there. Otherwise look on the manufacturers website for the drivers and other software you may want. the bluetooth device itself is just the hardware, you need both the software and the hardware, good luck,
PS, also mention what operating system you have, because XP doesn't support it even though it will work on XP, that's a MSFT thing,they would rather say they don't support something than have it work properlly with their software
SOURCE: I have a lenovo 3000 N 100 HBQ 0768 notebook which
try restoring to an earlier time when it did if this works its probably viral or software corrupted
SOURCE: lenovo 3000 N 100 integrated cam not coming in device manager
fistly you check ur bios setting & registry setting.
is that possible cam is disable by bios or registry, so kindly check it & reinstall ur cam driver.
