20 Most Recent HP Compaq 6820s Notebook Questions & Answers
Hi. I have a HP
try a new battery yet? (brand new fresh) sleep mode. so you want it to run for 7 days in sleep. ive no idea how long this laptop runs in sleep and hibernate is longer. no idea at all. you do know that the speed features are programmable right? including what chips do and do not go to sleep' like USB ports, WIFI, and all wake on , features. like Ethernet chip. and more. why not just turn it off, and let the battery last longer.. this mode sleep kills batteries faster. way faster. leave it plugged in all the time to the wall pack. so the battery never drains unless you need to use it, on battery.
7/18/2017 12:09:02 PM • HP Compaq 6820s... • Answered on Jul 18, 2017
Compaq 6820s freeze after few minutes
load a program called coretemp (you may download this on another computer on to a USB stick, transfer the stick and then run it from the flash drive). Are the temperatures near to the Tjmax value ? if so this may be why your computer is freezing after a while. It is probably clogged with dust. Clean it out (search the internet on how to do this) Another reason may be because you are using too much memory cut down on the number od programs/internet tabs you have open. Try restoring (system restore) back to point before this started happening Try updating BIOS to latest version, and also graphics drivers if applicable Finally it may be that your system board has become defective: some say its a problem with the southbridge chipset (may be overheating: this is still my favourite hypothesis)
5/21/2016 7:51:09 PM • HP Compaq 6820s... • Answered on May 21, 2016
HP 6820s - Brand New
hold the power button on the powered down unit for 20-30 secs and try again its called a static discharge and will usually cure an issue like yours its not a sure thing but give it a try ok :)
9/22/2015 3:37:57 PM • HP Compaq 6820s... • Answered on Sep 22, 2015
manual
2answers
Windows logon problem
so it logs you in and then logs you back out immediately? If that's the case try booting in safemode by hitting f8 during boot.
10/21/2012 10:49:28 AM • HP Compaq 6820s... • Answered on Oct 21, 2012
My Hp Compaq 6820s won't start. When I press
please send your correct mistake i can help you
2/12/2012 11:32:35 AM • HP Compaq 6820s... • Answered on Feb 12, 2012
My hp laptop won't power up. I bought a new power cord and connected to my laptop and the power light won't come on, so what esle can i do to get power to my laptop?
Have you followed the Guided Troubleshooting steps provided on the HP Support web site?These will take you through a series of checks and decisions to try to isolate the cause of the problem along the following lines:1. Are you sure you are plugged in to a good power outlet - can you plug a lamp in and does it work?2. Are you sure that you are using the right power adapter for this laptop, is it the original HP block supplied with the laptop or is it a replacement - if the latter, then does it supply the correct output voltage and watts required by the laptop.3. Are you sure the problem is not just the laptop display being dead, i.e. have you tried attaching an external display, do you get any leds light on the laptop for power, disk activity etc?4. Have you tried removing the battery from the laptop and connecting the power adapter with it removed to prove that the battery is not preventing the laptop from powering on?5. Have you disconnected all external devices from the laptop, in particular docking station, printers, USB devices etc to ensure that no external device is preventing it from powering on?6. Do you have another power adapter that you can try using - are there any lights on the power adapter to show that it is working?
1/5/2012 5:19:24 PM • HP Compaq 6820s... • Answered on Jan 05, 2012
I recently had my computer worked on, but my yahoo
Open Yahoo.com scroll to the bottom of the page you will see toolbar where you can download another copy. You can also use this link
http://uk.toolbar.yahoo.com/
8/15/2010 5:36:21 PM • HP Compaq 6820s... • Answered on Aug 15, 2010
Compaq 6820s does not turn on
This issue could be due to presence of static charges or internal hardware malfunction of the notebook. To isolate the exact cause of the issue, perform the following steps.
Step 1: Hard Reset
To perform a hard reset, please follow the steps listed below:
1. Unplug the AC adapter from the notebook PC and remove from any port replicator or docking station.
2. Remove the battery from the notebook battery compartment.
3. Press and hold down the power button for about 20 seconds.
4. Insert the battery and plug the AC adapter back into the notebook PC.
5. Press the power button to turn the notebook PC back on.
This will discharge the static charges from the notebook. Now check for the issue. However, if the issue persists, then it is clear that the issue is due to internal hardware malfunction of the notebook and requires a detailed onsite diagnosis by a service technician. At this point, if your notebook is covered under HP warranty, then I suggest you to contact HP support to get the notebook repaired under warranty.
6/2/2010 6:27:02 PM • HP Compaq 6820s... • Answered on Jun 02, 2010
My Hp Compaq 6820s don't start when I press power button.
This simply means that the battery is dead. Pull the battery out and try to start it again (with the power adapter plugged in obviously). If it starts up, you need a new battery, if it does not start up you may have a bad power adapter or broken power jack.
2/26/2010 5:23:30 PM • HP Compaq 6820s... • Answered on Feb 26, 2010
I did a backup and recovery. Followed instructions.
Hi
Try with recuva recovery software for your pic & video
Harry
8/8/2009 11:14:32 AM • HP Compaq 6820s... • Answered on Aug 08, 2009
0answers
2answers
Hp compaq 6820s starts for a few seconds and than shuts down
if the problem is from the power button.. check the power button. if powering its means not power button problem.. and also check the cpu fan if working or not... open you laptop if you can't bring to the shooroom or call qualified laptop technician to check you laptop..
6/15/2009 7:35:34 PM • HP Compaq 6820s... • Answered on Jun 15, 2009
3answers
I need to know how to turn on a HP X13-04657 LAPTOP, all the lights are on but nothing on the screen.
HP X13-04657, is 2007 PC THOSE this PC has CCFL back lamp strip that is dead.Vista era PC, laptops. are hard to work with now, 17 years old.is this not a HP COMPAQ presario HP X13-04657 (wrong name!) sorry !became HP in 2002. so is HP but manuals are super hard to find now. that x13 is part of the microsoft license code vista. (so is distraction to what it is)the real name of the Laptop is and was Presario CQ61 laptop CQ61 the PC has bottom sticker that shows the real names of PCs.CQ61-219TU is real name of on CQ61, there area many different sub codes, and they are not all the same.CQ61-306AX this had CCFL (cold cathode florecent lamps) that love to fail 3 waysdead, blinks ,dime or yellow = white.was made until 2009 and evolved, to LED backlamps.-410 is CCFLI will answer for CCFL as those just love to fail,but the the test is so easynow the answer for ANY laptop this old. 2007 and older. black screen all the time, and BIOS screens dead, answers only me. here. remove the main battery (large) it simply snaps off the bottom.the power pack is next we run the PC on your power pack AC to DC it must make the screen glow with something, do not use the wrong pack as in mixed up with others.now the lap top seems on, even the fan blows, LED glowpoint a flash lamp at the screen ,dark' room , and of you see any kind of LCD data on the screenthe CCFL lamp below #1 is bad.this is phase 1 testing, as other things can fail too. The keyword below is Mercurythis tells me it is those pesky CCFL glow tubes. 2007 is the year some PC went to LED back lamps. yes I was correct the service manual I did find proves they made both lamp types ccfl-hp07-psnmcz4s4yabbrmds04n13cd-d-0.jpg
4/17/2024 12:37:57 PM • HP Computers &... • Answered Yesterday
Dove posso scaricare il driver per HP ScanJet 8270? ente compatibile per windows 10...
Question edited for clarity. Question translated to English. We only speak English on this North American website. https://www.google.com/search?q=hp+scanjet+8270+driver+windows+10
HP Scanjet 8270 Document Flatbed Scanner
Hewlett-Packard https://support.hp.com > ca-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner ... drivers free of cost for Windows and Mac ... Windows 10 / ...
Hewlett-Packard https://support.hp.com > ee-en > drivers > hp-scanjet-827... Download the latest drivers, firmware, and software for your HP Scanjet 8270 Document Flatbed Scanner. This is HP's official website to download the correct ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Download
Softonic https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.softonic.com Download the latest and official version of drivers for HP Scanjet 8270 Document Flatbed Scanner. This driver package is available for 32 and 64 bit PCs. It is ...
HP Scanjet 8270 Document Flatbed Scanner drivers - Free ...
Download.it https://hp-scanjet-8270-document-flatbed-scanner-drivers.en.download.it Download HP Scanjet 8270 Document Flatbed Scanner drivers varies-with-device. Software drivers for the 8270 flatbed model of the HP Scanjet printer. ..
4/10/2024 8:38:39 PM • HP Computers &... • Answered on Apr 10, 2024
2answers
HP 8440P Laptop. I don't remember my password. Help needed for HP 8440p.
This video shows you what to do if you forget your computer password:
4/6/2024 8:00:24 AM • HP Computers &... • Answered on Apr 06, 2024
2answers
How to do a bios recovery on a hp pavilion dv5-1004nr
This video shows you how to restore the BIOS in your computer:
4/6/2024 7:57:59 AM • HP Computers &... • Answered on Apr 06, 2024
Hp dv8 not charging battery
You can follow the steps in this video to troubleshoot your battery:
4/6/2024 7:13:37 AM • HP Computers &... • Answered on Apr 06, 2024
HP Compaq 6820s Notebook Logo
21 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp
  • Computers & Internet
