I have replaced my black ink cartridge, but now when i want to print or do test print all the the colors appear but the black. As i was trying to get it to work now it saids that i need to replace the colored ink(yellow and cyan). NOw it wont let me print anything or test print at all, even though it reads that the black ink is full.
Depending on the cartridge, there is a little chip inside and they can malfunction. so take it back to where you bought it, or contact the manufacturer.
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
SOURCE: Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until
all startup noises have stopped. Open lid and reinstall cartridge. This
will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have
seen this over and over. Two cartridges empty at the same time, and the
person replaces one of them but thinks they actually replaced the other
one.
Turn the power off and pull all the cartridges out. Look a the side of
the cartridge, you should see a window with a little plastic tab
sticking out. This tab should be blocked by a black float inside the
cartridge. If you cannot see the float, and the tab is clear with no
ink in it and no float tab blocking it, it means the cartridge is empty
even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the
noises have stopped, open the lid and install the cartridges. If you're
still getting an error saying either a cartridge is not installed or is
empty, then one of your cartridges is empty. Redo the previous
paragraph.
SOURCE: Is there a way to get Brother MFC-240C to only use black ink cartridge?
Theres a simple trick to cheat the machine.
BUT
you will definitly destroy the printhead when doing so for a longer periode!
You have to put some black adhesive tape around the middle part where you can see this black palstic flag inside the cart. This flag signals the printer that the cart is insert and later on when the ink is down to give the waring: near empty.
I do give you the advice to do another but saver cheating:
You can refill the cart with a mixture of 8 ml destill water and 3ml 85%-Glycerol (e. g. Glycerin alc. which can be bought at a drugstore for a few cents). Shake the mixture well (within the syringe) before refilling the cart.
See pics here how to do so (LC1000):
http://www.hstt.net/refill-faq/brother.html#LC-1000 - Refill
(brother has changed the construction of the carts! If you can see a plastic quad in the middle of the cart, you have to drill the hole just behind the air valve (white plastic looking out of the cart)
SOURCE: can you force a printer to print in grayscale?
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
