you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Not familiar with Frontier...most email programs has a "print view" option...if not try highlighting by click & drag across what you want to print, click file at top left,print, selection,ok
To cancel one or more print jobs, follow these steps.
Click Start, and then click Run.
In the Open box, type control printers, and then click OK.
Right-click the icon for your printer, and then click Open. To cancel individual print jobs, right-click the print job that you want to cancel, and then click Cancel.
There is a problem with the printer. Press resume button again and see if the light orange light goes off. If not then switch off the computer wait for sometime and start again. If it still persists read the error code.
A printer prints almost anything that is shown in a computer screen and it depend on what you're trying to print. If you want to print contents from a webpage, you have two options to chose from. The first is of course the contents in the webpage that you want printed and the second option is to print the whole webpage. If you want to print only the contents in a web page, e.g. an article or photo, you have to highlight the article or photo first then right-click and select 'Print...'. It should print the article or photo only. But if you want to print the whole webpage, chances are that it only prints the 'skeleton' of the webpage and not the contents, hence the reason you have only the left part of the webpage printed. However, if you highlight the whole webpage and then right-click and select 'Print...' I am sure you will have the whole webpage printed. Cheers.
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Try feeding one by one first. Spread the "legs" and drop gently up to ten pages in the directional manner. Hope for the best. It could be that the pinions are worn out and thus it lacks the grip.
