First, the display images disappeared. It was still backlit and would turn on, just no information displayed. Then, two days later, the display failed completely and the treadmill will no longer turn on. Any advice on how to repair this would be greatly appreciated.
SOURCE: with Nordictrack C2000 checksum : fail appears on
This is a sign of a bad console. They may be able to flash the machine using the i-fit sd card slot. Go to iconservice.com for contact info.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: NordicTrack 2500 R Treadmill
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Remove
the bolts or screws securing the console to the upright assembly.
Lift the console and confirm that the cable connections are secure.
Remove the cover from the console's battery bay and install a fresh
set of batteries. Replace the battery cover.
Detach
the ends of the pedals from the crank axles. Remove the left and
right disc shields and side shields. Inspect the interior of the base
unit and locate the flywheel.
Inspect
the flywheel as it turns. Locate the magnet installed on the
flywheel. Turn the flywheel until the magnet passes in front of the
nearby reed switch. Loosen the screw securing the switch in place.
Rotate the switch to reduce the gap between it and the magnet.
Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
The way to tell if your NordicTrack digital console is bad is to troubleshoot it first. If nothing works, you've got a bad console. The digital console is an important part of exercising. A manual machine will still work even if the console doesn't, but an automated machine needs the console to work so you can adjust things like speed, resistance and incline. You also can't use programs or see your time, distance or estimated calories burned without a working console. The two most common reasons that a console will be dim, display bad results, or won't turn on are bad batteries and a problem with the reed switch.
