JUST NEED TO TAKE THE OUTER CASING OFF REMOVED 5 SCREWS BUT STILL FIXED. HAMMER NEXT!!
Hi Please check this link to get an idea
about how to pull the cover up from the body of the printer,though it is a
different model that has been shown but the edition of the printer is same
which is Epson Stylus Photo :- http://www.ifixit.com/Guide/Disassembling-Epson-Stylus-Photo-820-Top-Cover/5606/1 Hope it is helpful. Thanks for contacting fixya.com Please do get back to us for further
query.
Testimonial: "Many thanks........why do they make it so difficult????"
SOURCE: Epson Stylus Photo R200 and R320 Status monitor in Vista
Hi - I have the R320, I downloaded the following driver epson11889_easyprint_310a from epson site. I uninstalled previous driver which was for the r200, installed this one and everything OK Status Monitor works fine.
Brand
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Reset your printer. Look for printer resetter , its a utility third party program. Or in search of web browser just key in " epson reset software"
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
small piece of paper jammed but cannot get outer casing off
