eMachines ET1641-02w (PT.NA60X.001) PC Desktop Logo
Rudy Posted on Jan 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My computer won't boot?
I turn on my computer, the power comes on and the light is on the fan is on but no sound and a black srceen.
Ray Smith
Level 2:
  • Expert 124 Answers
  • Posted on Feb 07, 2015
Ray Smith
Expert
Level 2:
Answers
124
Questions
0
Helped
38836
Points
383
Try removing the CMOS battery, wait 15 minutes put it back in and see that that helps. Try reseating your memory sticks. If you have more than one, test them singly and swap slots. Good luck.
1 Related Answer
Ezrahite
Rofel Lantican
  • 2632 Answers
  • Posted on Sep 10, 2011
SOURCE: My emachine C3070 won't run!
Welcome to Fixya. I would like to verify some importand details about the issue so that we can determine the cause of the problem. When you turn on the computer the power indicator, cooling fans and hard drive works but there is no display on the monitor is that what you meant? If this is happening on the computer it is called no boot, no display or no post. POST is the power on self test that you will see incase you turn on the computer. In your case since the monitor is working on the other computer it means that that is ot the problem. If no display happens on a computer an you are using the onboard display the problem is the MOTHERBOARD. Please stop tuning on the computer because this might case other problem on the other device on the computer like the hard drive, memory and the processor. It would be better to chage the motherboard of the computer or check the warranty of it then bring it to acer or emachine service center for them to replace it. CMos battery will not fox this issue. Start up disk won't either because this is a hardware issue.
If you have questions please let me know. Thanks for using Fixya.
Acer am1100 won't start up
Discribe what happens when push the on/off button and you try to boot, fan spin? LED's blink? HDD/DVD light blink? Sound? Any thing on screen at boot? What blue light?
Won't boot up and fan not running
Sounds like a dead battery or power supply or both...check for a light on the power supply to prove it's connected.
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
M17x won't power on but keyboard lights work
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working. I was fine yestyerday. I put in hibernate and tried to cut back on today...
Remove the RAM and install it again and restart.....it will work if still not work then change remove RAM again and start your machine..it will give beep sound...if it will not give beep sound then understand your machine's mother board is faulty......
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
