20 Most Recent
eMachines ET1161-07 Desktop PC Questions & Answers
My emachines desktop ET1161-07 is randomly playing a high-low beep
A virus check might not get all malware. Download Malwarebytes free and do a scan with that. Check the add-ons installed in you browsers and get rid of superfluous or strange ones. Use msconfig to check which programs are loaded at start up. Uncheck unnecessary or suspicious ones. Good luck.
2/7/2015 1:24:36 PM •
eMachines...
Answered
on Feb 07, 2015
Manual for et1161-07
That's easy. Open the side panel of the CPU. Locate the battery on the motherboard. Pull it out. Place a fresh one.
8/11/2014 1:35:45 AM •
eMachines...
Answered
on Aug 11, 2014
Hdmi port
yes there is but you have to but HDMI card.
3/17/2014 1:19:45 AM •
eMachines...
Answered
on Mar 17, 2014
EMachines running XP. Computer kept shutting down
Most likely a hard drive problem. When you get the flashing cursor, it indicates a lack of an accessible Operating System. But, if the drive was good you would get a boot failure indication. I would try booting with an XP disc and look for the HDD (or try F2 when you boot) to get to the BIOS and look for the drives there.
9/3/2013 8:03:37 PM •
eMachines...
Answered
on Sep 03, 2013
No power
A) Power On switch is no goodB) Power Supply is no goodDo you wish to perform the simple test, to see if the problem is the Power On switch, or Power Supply?If so post back in a Comment.Also, IS it an eMachines ET1161-07 Desktop PC?Don't want to 'rattle my lips off', if it's a different computer.
http://www.directron.com/atxswitch.htmlPost back in a Comment.Regards,joecoolvette
5/7/2013 4:18:26 PM •
eMachines...
Answered
on May 07, 2013
Hook up pc tv
Need more information. Are you using VGA, HDMI S-Video?
4/29/2013 7:33:00 AM •
eMachines...
Answered
on Apr 29, 2013
MY EMACHINES COMPUTER IS STUCK IN SAFE MODE
hi ...
whn you say the computer boots up in safe mode..
in this list you should have an option called as load windows normally (similar to this)
use the arrow keys and select it.. and then press enter and please do let us know what happens..
it should ideally work...and if it boots up to your desktop please investigate..
4/11/2013 2:18:57 PM •
eMachines...
Answered
on Apr 11, 2013
Reset password emachine
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :-
http://www.hirensbootcd.net/ http://67.20.82.163/
11/19/2012 9:20:56 AM •
eMachines...
Answered
on Nov 19, 2012
