Elements are not made by the manufacturer and generic in design
to that end you go to electrical wholesalers and taking you old elements along , see if there is a like one that fits
depending on where you are there are retailers that sell elements for just about everything and e-bay has a range of elements
you have to make sure of several things
1-- the end fittings are the same
2-- the wattage is the same and the shape is the same and --the dimensions are the same
all of this you can get by reading the description on the sellers page
SOURCE: 1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
SOURCE: GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
SOURCE: GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Testimonial: "thanks!"
SOURCE: GE P7 Double Oven, upper ovens heating element not
you have what is called a "Hot-Spot" in the element and it burned thru,now you need to replace the element
