20 Most Recent
GE JKP15 Electric Single Oven Questions & Answers
GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
7/12/2019 4:10:01 PM •
GE JKP15...
Answered
on Jul 12, 2019
What is the ground & neutral wire for a JPK15 GE Oven?
Assuming this is in the USA there are 3 wires normally in a 240 volt circuit. A black, red and white. Sometimes there is a bare ground wire. The white wire and bare ground wire are basically the same.They connect to the same place in the electrical box. The red and black are your power wires. They would connect top the outside connectors and the white and bare wire (if supplied) would connect to the center connector.
5/9/2015 1:49:05 AM •
GE JKP15...
Answered
on May 09, 2015
GE Wall Oven Gasket Replacement
If you cannot find this on the net, contact the GE Appliances parts supplier for your area and order the service manual. Usually these are not free. There is some not easy to do un-assembly required. For safety you'd be best to have a service call from an authorized GE service rep.
9/6/2014 7:06:02 PM •
GE JKP15...
Answered
on Sep 06, 2014
How do you get rid of beeping and F O error
Try turning the house breaker of for a few seconds, then back on. Maybe it will reset. I looked for a manual for you, but haven't found one for free. Sorry. If turning the power off doesn't work, come back and we'll try to figure out something.
4/27/2014 9:27:45 PM •
GE JKP15...
Answered
on Apr 27, 2014
Owner manual pdf
http://data.manualslib.com/pdf/6/584/58309-ge/jkp15.pdf?e5f6a2c77a078937daa77d391da45be4
12/9/2013 2:25:55 AM •
GE JKP15...
Answered
on Dec 09, 2013
Built in GE wall oven
why are you trying to remove the panel are you talkin about the control panel
5/11/2013 9:53:06 PM •
GE JKP15...
Answered
on May 11, 2013
