20 Most Recent KitchenAid Architect Series KEBC107KSS Electric Single Oven Questions & Answers
14answers
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
12/3/2021 8:21:00 PM • KitchenAid... • Answered on Dec 03, 2021
3answers
Error code F6E0 on Kitchenaid KGSS907000 wondering if it is the control board or touch screen, what other components could cause this?
F6 - E0 Return line not connected If switch pulse return line is not connected, electronic control will display F6 within 60 seconds after power up. Replace control board
10/16/2021 5:03:30 PM • KitchenAid... • Answered on Oct 16, 2021
3answers
Kitchen aid oven
We offer replacement oven and oven/microwave touchpad for no longer manufactured Kitchenaid units. We also have the control boards available. Please reach out to us with your model number for more information. [email protected] fixyourboard.com ledgestone ka keypad-crjxtk2pui4xc5qqbhljddcq-4-0.png
8/7/2019 5:22:12 PM • KitchenAid... • Answered on Aug 07, 2019
2answers
How do I use the thermometer in my Kitchenaid
I found the answer by checking the Kitchenaid website to find the manual. My model is KEMS308sss04, this is found on the right door frame. Website is: http://shop.kitchenaid.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10162223.pdf
You can preheat oven, but then turn off to set thermometer. Put probe in food. Put food in oven and plug in probe. The digital light asks for the temperature you want, type it in. Then the cooking method. I used convection bake at 325. Hit START. (The first time I didn't stop the oven and it didn't work. After stopping everything and starting with the probe before turning on the oven, it worked perfectly. Good Luck.
11/21/2017 4:06:39 AM • KitchenAid... • Answered on Nov 21, 2017
2answers
Oven preoblem kitchenaid ykers807sp
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem! ledgestone kp1b1705-vce5mquz3yp03nzfysmmck3z-1-0_1.png
9/12/2017 11:13:22 PM • KitchenAid... • Answered on Sep 12, 2017
0answers
MY KITCHENAID STOVE DISPLAYS FEATURE NOT AVAILABLE WHAT DOES THAT MEAN
Need replacing EOC board interface
2/2/2017 10:10:23 PM • KitchenAid... • Answered on Feb 02, 2017
The time won't stay lit on the oven. What do I do?
Sounds like it is in the energy save mode or does the display go blank when the start button is depressed if so then probably a bad User INterface
2/13/2015 2:03:03 AM • KitchenAid... • Answered on Feb 13, 2015
Kerc507hbt0 oven won't heat
Chances are that the thermal fuse on the back of the oven has gone out. If you used the self clean feature and then it didn't work this is more than likely the problem. If not then it coulkd be an element that is bad or a control board oproblem.
3/2/2014 6:11:34 PM • KitchenAid... • Answered on Mar 02, 2014
10answers
OVEN will not heat
After reading the above, here is how I fixed my KEBS177DSS9
I pulled out the wall oven from the cabnet. Took off the back tin panel about 10 tin screws. Follow the wire from both heating elements. They are both connected to a thermo fuse. When using the self clean feature this fuse protects the oven from over heating and starting a fire. I put a jumper wire from the hot lead on the left and connected it to the 2 leads on the right side. I turned the power back on and turn the oven on to bake at 350 degrees. Yep It worked like a charm. I bypassed the thermal fuse and used the oven, until the new thermal fuse was ordered. If you have any questions about this fix email me at [email protected] Good luck
12/2/2013 1:11:56 AM • KitchenAid... • Answered on Dec 02, 2013
Error code F5E1
According to the manual, If the error code is a letter followed by a number, you need to reset the display.
Press LOWER OVEN CANCEL / OFF, UPPER OVEN CANCEL / OFF or CANCEL OFFIf it comes back it needs to be serviced call 1-800-422-1230.Please rate my solution, Thank you
10/26/2012 4:41:58 PM • KitchenAid... • Answered on Oct 26, 2012
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
108 questions posted
Top KitchenAid Ovens Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Ovens
  • KitchenAid Ovens
Most Popular Question
time stay lit oven
  • Ovens
