I have power it starts out in protect and then the red light turns off but the green one never turns on everything else is lit blue as normal but I get no sound out the amp I assume my out put is shot where can I get it repaired and for how much?
It sounds like the switching power supply has failed.
You need to find a local repair shop. If you don't know of any, contact the local car audio dealers to see who they use. If several recommend the same shop, they probably do good work.
If you want to try to repair it yourself, you'd have to do a bit of troubleshooting.
not a solution but i have a 50gx30b doing something similar, no picture no sound, 3 green leds are lit up on the main board and then one red led lit up also on main board, front panel red led stays on for about 30 -50 seconds and then it all shuts off, I then have to unplug and replug to get the same results.
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
3 screws aqre visible they usually hold 3 wires
black green and red. if they have losts of black wound together it means they are in series with other lighyt switches. Ideally get an electrician in.
anyway unscrew the wires from their holders and attach a new swtch placing wires basck in the same congfig. RED is LIVE Black is RETURN ( Usually) and Green EARTH.
(Sometimes live and return may be blue and brown)
put cover back on replace fuse and turn power on and hope there is no "bang" because you put wires in wrong way
Generally, if a Kicker amp has the power light lit and the protection light isn't lit, it's working. Are you sure that you have signal feeding the amp?
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
