Konica Minolta DiMAGE Z3 Digital Camera Logo
Posted on Jan 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to format memory card - Konica Minolta DiMAGE Z3 Digital Camera
Jose Cada
Level 3:
  • Master 3,530 Answers
  • Posted on Jan 30, 2012
Jose Cada
Master
Level 3:
Answers
3530
Questions
Helped
965477
Points
9839
Hi. Welcome to Fixya! you can format the meory card using your computer. Plug-in the mem card to a laptop that has a card slot reader. Access the card by right clicking on it then select ENTER.
Cheers!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
4helpful
2answers
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
28helpful
5answers
Memory card not formated operation failed
Sometimes, Due to viruses or hidden data in the memory card, the handset is unable to format the memory card. so if u format it from a pc, using a card reader, your mem card will surely get formatted easily.. But if there is some technical problem in formating, download HP DRIVE KEY BOOT UTILITY It repairs up and formats the corrupted data and your memory card will be ready to use again .. Happy formatting !
3helpful
3answers
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
7helpful
When iam opening memory card in nokia 3110c it is saying memory card not formatted operation failed.please guide me what to do
Hi, problem can solved.When a memory card says formatted operation failed,it means the memory has been affected with VIRUSin it,thats why it's not given you access to get into it.
What you will need to do is to format it.
You can use your phone to format the memory card by going to the option of the memory card and click on format memory card.
Also you can use a PC to format the memory card by using a memory card reader. insert the memory card inside the card reader and connect to your PC, click on my computer, you will seethe memory card icon displayed, right click on the mouse for options to come up, and click on format memory card and you done.
Note: When trying to format and it does not format the memory card, that means the VIRUS that affected the memory has damaged it totally, that means you will have to get a replacement memory card.
Thanks for using fixya....
25helpful
5answers
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
2helpful
My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
3helpful
3answers
How to i format my memory card for nokia 7373, its a new memory card, but when incerted it says, memeory card not formatted.
Just goto Menu -> tools -> memory
1. select Memory Icon.
2. Press Options
3. Select Format Memory card
4. Thats all.. your memory card will be formatted and ready to use.
I hope this solves your problem.
Thanks
9helpful
My Z740 won't format my memory card. When I turn
My Z740 won't format my memory card. When I turn it on - it says memory card needs formatted. I tell it to format - and it just repeats the Memory Card requires formatting message.
1helpful
Cannot find instructions in manual for Nikon Coolpix S210 on how to delete ALL photos from memory disk. It will let me delete one at a time but I want to wipe the memory card clean. Thanks for any and all...
These instructions are from the Instruction Manual of the Coolpix S 210 and need to be carried out within the Set-Up Menu.
Refer Page 19:
Removing Memory Cards
Before removing memory cards, turn the camera off
and confirm that the power-on lamp is off. Open the
battery-chamber/memory card slot cover and press the
card in 1 to partially eject the card 2. The card can
then be removed by hand.
B Formatting Memory Cards
If the message at right is displayed, the memory card must be
formatted before use (A110). Note that formatting permanently
deletes all pictures and other data on the memory card. Be sure
to make copies of any pictures you wish to keep before formatting
the memory card.
Use the multi selector to choose Yes and press k. The
confirmation dialog will be displayed. To start formatting, choose
Format and press k.
Do not turn the camera off or open the battery-chamber/memory card slot cover until
formatting is complete.
• The first time you insert the memory cards used in other devices into the COOLPIX S210, be sure to
format them using this camera (A110).
Refer Pg 110:
 Format Memory/m Format Card
Use this option to format the internal memory or a memory card.
Formatting the Internal Memory
To format the internal memory, remove the memory
card from the camera.
The Format memory option appears in the setup
menu.
Formatting a Memory Card
Format card option appears in the setup menu.
Hope this helps
Ian
22helpful
5answers
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 • Nokia 6600
Top Konica Minolta Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
