20 Most Recent Nikon COOLPIX L5 Digital Camera Questions & Answers
System error
Look for a reset function in camera manual If no manual download one - if nada, then contact Nikon customer service for inside assistance with dilemma. Due to high cost of camera repairs you just might have to go shopping.
8/26/2017 1:09:23 PM • Nikon COOLPIX L5... • Answered on Aug 26, 2017
2answers
HOW TO CONNECT MY NIKON COOLPIX L820 AS WEB CAMERA
You are all idiots, He asked how to use it as a webcam, not how to read the pictures on it.
6/2/2017 11:34:48 PM • Nikon COOLPIX L5... • Answered on Jun 02, 2017
How to reset camra nikon coolpix l5?
Start in the record or playback menus go to the setup menu scroll down to reset all.
8/24/2016 8:36:01 PM • Nikon COOLPIX L5... • Answered on Aug 24, 2016
Usb cable for coolpic l820 how much are they
You need a Nikon UC-E6 cable. Amazon.com has them for $4.60. The list price is $10.95.
8/31/2014 4:09:45 AM • Nikon COOLPIX L5... • Answered on Aug 31, 2014
I have a Nikon coolpix l5 that won't zoom in or out all the way got any ideas on how to fix this?
Your camera is an older 7.2 Mega-pixel low resolution camera and the cost of repair would be far more then the $17 to $23 value I see on E-bay. I would recommend that you upgrade to one of the newer low cost (under $100) cameras that all have at least 12 Mega-pixel resolution.
8/3/2014 5:38:26 PM • Nikon COOLPIX L5... • Answered on Aug 03, 2014
How do i watch videos on my polaroid a530
In the manual it says this: e381e201-8d79-44da-92bd-310e554e5327.png I found the manual here: pdfretriever com
6/24/2014 12:53:43 PM • Nikon COOLPIX L5... • Answered on Jun 24, 2014
Write protected card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
6/11/2014 4:01:02 PM • Nikon COOLPIX L5... • Answered on Jun 11, 2014
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
5/25/2014 3:15:54 AM • Nikon COOLPIX L5... • Answered on May 25, 2014
Where is my memory card
The memory card slot is in the battery chamber. If you have lost your manual you can download a copy here: https://support.nikonusa.com/app/answers/detail/a_id/14109
12/15/2013 4:51:36 PM • Nikon COOLPIX L5... • Answered on Dec 15, 2013
Systemfehler
Systemfehler is a German band, but the translates to "system error"...try changing the menu back to english and then go to the Nikon support web page and see if there is a firmware upgrade available. Good luck!
10/12/2013 7:07:41 PM • Nikon COOLPIX L5... • Answered on Oct 12, 2013
Picasa no longer recognizing Nikon Coolpix L5
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Picasa or any other photo cataloging program.
2/1/2013 3:06:25 AM • Nikon COOLPIX L5... • Answered on Feb 01, 2013
How do I open the battery door?
Follow the numbered arrows in the first diagram on page 12 of this manual.
1/19/2013 9:41:09 PM • Nikon COOLPIX L5... • Answered on Jan 19, 2013
2answers
I need to download the drivers for my Nikon Coolpix L5 camera
hello, how are you?, ther are many sites to download drivers but its very difficult to find out perfect site. i am giving you a link, on which you can find your nikon drivers. just type--- NIKON COOLPIX DRIVER FOR (WINDOWS XP/VISTA)
http://driversdownloadsfree.com/tag/download-nvidia-graphics-card-driver.
You can see a serch box and many products which are related to software companies(in left side) so lets try this.
best of luck atul kumar
12/13/2012 1:07:58 PM • Nikon COOLPIX L5... • Answered on Dec 13, 2012
My querry is the opposite: how can I transfer pictures FROM my pc TO my camera.
Most cameras will not display pictures that have been edited in any way on a computer. Opening a photo and saving it without making any changes counts as editing.If the picture is an unedited picture from the same camera, make sure it's in an appropriate folder inside the DCIM folder.
12/3/2012 6:40:24 PM • Nikon COOLPIX L5... • Answered on Dec 03, 2012
TRANSFER IMAGES FROM MY PC TO THE CAMERA
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
12/2/2012 4:23:39 PM • Nikon COOLPIX L5... • Answered on Dec 02, 2012
If sd card is inserted then camera screen is blank and lens doesnot move.without memory card camera works fine
Try a different SD card. it maybe faulty.
10/27/2012 5:11:42 AM • Nikon COOLPIX L5... • Answered on Oct 27, 2012
Nikon coolpix l5 has stopped working if sd card is inserted.without sd card camera works normally
The SD card maybe faulty, try a different SD card.
10/27/2012 5:09:56 AM • Nikon COOLPIX L5... • Answered on Oct 27, 2012
3answers
Camera says this card cannot be used on power up.
either the card is not supported or it needs formatting
8/26/2012 11:01:45 PM • Nikon COOLPIX L5... • Answered on Aug 26, 2012
Nikon COOLPIX L5 Digital Camera Logo
80 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
connect nikon coolpix l820 as web camera
  • Cameras
