20 Most Recent
Konica Minolta DiMAGE Z1 Digital Camera Questions & Answers
Where can I find a battery door replacement? Mine is cracked.
It will be difficult to get but tray a camera shop as they may have access to parts
failing that I see a new product on the market where you place a small amount of liquid on the broken edges and then apply an ultraviolet light to send it of and it makes a perfect weld
the whole thing is about the size of a small torch and according to the ad it works well
it is a product from your country so you should have the adds running
Viewfinder not coming on!
I found this "solution" on another site and it actually worked!
Turn the camera upside down. Now, with the device off, tap it a few times in your hand. Now, turn the device on in the viewfinder mode. Tap it again if the viewfinder isn't active.
Dimage camera unable to use card
What type and size memory card are you trying to use? The Z1 works with MMC and SD cards, 2GB or smaller. It will not work with higher capacity SDHC cards, even though they fit into the slot.
Format sd card
Press the Menu button on the camera and scroll through the menu until you get Format memory.
Battery cover
Sony has bought-out Minolta. Parts for Minolta equipment has become scarce, but try here: http://eservice.sony.com/webrma/web/index.do
Keep getting error message when I plug usb into computer to download pictures
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
