I recently purchased a barracuda pool cleaner. As soon as I connected it up it wopuld work spasmodically and move a few inches then the water pressure would drop and hardly any water coming out of the return inlets but lots of buddles. The supplier then sent me a skimtrol skimmer plate instead of my lockin poolrite plate. By adjusting the flow on the skimtrol I can get a correct reading on the pulse meter of between 2 and 3 as suggested. However as soon as I connected the hose the pressure drops and the bubbles start again. I have checked all the hoses for splits etc.and the actual barracuda head looks fine - no tears or anything. I have spent so many hours trying to find the problem. The O rings look perfectly fine and the pump works well without the cleaner attached. Can anyone help me please?
Its not uncommon to get some bubbles when using sectional hose as there are 12 connections that must be tight (but usually leak a bit). if you have access to a regular one piece hose, try using that to see if the problem corrects.
these machines are horrible for diaphragm problems which is why there is usually a big bin of replacements at every pool store. even though there is no tear, the rubber may have stretched or become rigid (water balance causes this)
SOURCE: G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
SOURCE: barracuda don't move
what do you hook your vacuum to in the pool? does it have suction? it may be clogged. if so you can blow it out if you have the equipment. it may be you don't have enough suction and all you need to do is adjust one of your suction side valves to fix this problem. if you don't have dedicated valves you can plug one of you other suction lines to give your vacuum more suction.
SOURCE: zodiac barracuda G3 isn't pulsing
These cleaners have a diaphragm inside that opens and closes that causes the unit to travel. If the diaphragm is bad, it will just stay still. Right above the handle there is a nut, separate the top part of the cleaner and you should see a white tube. Push that white tube downward and pull it out of the bottom of the unit. You should see the rubber diaphragm, check to see that it is free of debris and if it is distorted. The opening inside the diaphragm should look like a fairly uniform ****, not a huge gap. If it looks like there is a large opening inside, replacing it will make it run like new. Hope this helps.
SOURCE: when the pool pump is working water flows freely
If you are seeing air bubbles in the leaf pot on the pump, you have an air leak on the suction side somewhere between the pump and the pool. Check the pump lid o-ring for any dirt, leaves, etc. Make sure the O-ring on the lid is not cracked, dry (lubrication like Aladdin's Magic Lube) or compressed or flattened. Also check your union or threaded connections to the pump suction (end) to insure they are tight and sealed. If this is an in-ground pool, and equipped with valves to control skimmers and bottom suction, close each valve separately to see if the air bubbles diminish. If the bubbles diminish when the valve is closed, then the air leak is in the closed section from that valve back to the pump. If the air leak increases, the air leak is in the still open line. Since the Kreepy crawly works on suction and increases the vacuum, the air leak will become more apparent, resulting in a loss of pump efficiency and flow, resulting in lost performance on the cleaner. If so equipped, close off the bottom drain valve and increase the suction on the vac line. I can provide further details as needed, but will need more information from you regarding actual equipment layout.
