20 Most Recent
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Questions & Answers
Flips over
There is a float in the body of the cleaner that keeps it upright. Uour pool store will have this and can change it for you also.
When to buy a new diaphram
the smallest tear in the diaphragm sill cause poor operation. if you know yours is damaged, change it. if you feel it and it is not soft or feels rough, it is time to change it. if you have not been cautious with your pool chemical balancing, chances are within a couple of years it will need to be changed
Pulse changes speed on baracuda
as there are no real moving parts on the barracuda, the pulse is driven by the efficiency of the pump. if there is air in the system, the pulse will slow down. as the air is expelled and the pump becomes more efficient at moving water, the pulse will increase.
Won't go to shallow end
Use your flow gauge to verify proper flow. Ensure return fittings are directed down. Add a return
diverter if necessary. Most often, one of these will be the problem causing these
pool cleaners to not clean the entire pool. Also, make sure hose is not coiled or kinked. Lay in sun to straighten if necessary.
