20 Most Recent
Zodiac Baracuda G4 Automatic Pool Cleaner Ne221 Questions & Answers
My baracuda super g + gets stuck on an upstand
2 possible answers.
1 have you put a deflection ring on the cleaner. If not do so
2 you could use a hose motor to pull the cleaner away from the upstand. A hose motor is a cuff that goes on the hose about half way and pulls the hose along. On a long/wide pool you might need 2.
Moves slowly and the stops. looks like diapham
This seems to indicate insufficient suction from skimmer. Confirm that all other skimmers are closed off properly. Suction can be checked by disconnecting suction hose from pool cleaner and placing your hand over the end of the hose. Suction hose may also have an obstruction which will inhibit proper operation.
Pool vac.
Is it getting enough suction? What type and size of pump is on the pool? If you have Intex or similar those are not strong enough to run a cleaner. Check your filter to make sure it is not clogged. The flow of water through the unit is what holds it to the floor.
