Most of the time a flash code of 8 means the controller has a fault. but sometimes there maybe a damaged cable connecting the joystick to the controller.Sorry for the bad news. Strege Mobility
Check the speakers connection and that should give you at least 8 of the colors. The ones left then are going to be ground and power and display power. You can figure those out with a meter.
The color flashing tells you how close you are to a full charge. The orange/red flashing should change to yellow and finally green. Sorry I have an original model so your's might be slightly different. Does it never change from orange/red?
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
its of Paper count problem. tourn of printer power and open the back cover and find the IC 366...... ita a small 8 pin ic just short Pin NO 1 And 4 just restart the printer ur problem has been resolaved
There are actually some certain meaning on the red light and green
light showing different information to user. The summaries are: 1) Green On, Red Off = Printer Ready. 2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up. 3) Green Fast-Flashing, Red Off = Printer off-line. 4) Green Slow-Flashing, Red Off = Processing Data. 5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing. 6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset. 7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted. 8) Green Off, Red Off = Printer power is off. 9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode. 10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
568-B Wiring Pair Wires RJ-45 pins 1-White/Blue White/Blue 5 Blue/White 4 2-Wht./Orange White/Orange 1 Orange White 2 3-White/Green White/Green 3 Green/White 6 4-White/Brown White/Brown 7 Brown/White 8 568-A Wiring 1-White/Blue White/Blue 5 Blue/White 4 2-White/Green White/Green 1 Green/White 2 3-White/Orange White/Orange 3 Orange/White 6 4-White/Brown White/Brown 7 Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Pin Std Phillips 1 White/Orange BLUE 2 Orange Orange 3 White/Green Black 4 BLUE Red 5 White/Blue Green 6 Green Yellow 7 White/Brown Brown 8 Brown White
