20 Most Recent Mitsubishi WD-73827 73" HDTV DLP TV Questions & Answers
2answers
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
3/7/2018 7:20:08 PM • Mitsubishi... • Answered on Mar 07, 2018
Mitsubishi WD 65737 black screen
Sounds like the back light has gone mate. Unfortunately this usually makes the tv obsolete
12/22/2017 4:56:35 AM • Mitsubishi... • Answered on Dec 22, 2017
0answers
2answers
Small white dots have started to appear on our
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
8/31/2016 8:51:09 PM • Mitsubishi... • Answered on Aug 31, 2016
How do I fix white dots on my Mitsubishi DLP TV?
Hello. Please call Mitsubishi! Some models the DLP chip is covered under warranty, and all you have to do is pay labor costs, our shop charges $200.
8/10/2016 1:22:05 AM • Mitsubishi... • Answered on Aug 10, 2016
Lamp status flashing orangey red
Your lamp door switch isnt activated. either the door isnt secure or the wire isnt plugged in. Flashing orangy red LED means just that.
5/14/2015 8:44:47 AM • Mitsubishi... • Answered on May 14, 2015
2answers
COLORS ARE LIKE A NEGATIVE
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
5/2/2015 11:41:29 PM • Mitsubishi... • Answered on May 02, 2015
2answers
Mitisbuski 73737 made popping sound and cut off
Check your lamp. The popping sound was most likely the arc tube exploding. Make sure you only install a real Philips or Osram lamp. WD73737 Mitsubishi Genuine High Quality Original Projector Lamps now... These folks have good lamps.
4/29/2015 4:10:23 AM • Mitsubishi... • Answered on Apr 29, 2015
I have picture but after about 10min picture gets distorted
That may be a power supply problem. The capacitors are known for failure. check google for "wd73827 capacitors"
3/2/2015 6:26:55 PM • Mitsubishi... • Answered on Mar 02, 2015
2answers
How do we set the picture to 1080 megapixels from
U can't just do it on ur own setting like 480i to 1080p when ever u want.No,u only get what ever the tv stations modes they set and send out only.Ur tv have the 1080p mode capability mean ur tv can pickup that 1080p mode.Dosen't mean u can change 480i to 1080p by ur self anytime u want,if the tv station is broadcating tv signal to u only in 480i u get only 480i.
2/16/2015 4:47:28 AM • Mitsubishi... • Answered on Feb 16, 2015
How to replace chip on Mitsubishi tv to fix white dot problem
Here's a link on to replace the chip on the DM board.....tks.....https://www.youtube.com/watch?v=JgiZdc4kZDw\
1/31/2015 5:17:28 AM • Mitsubishi... • Answered on Jan 31, 2015
Why does there seem to be very little brightness even when adjusted higher ?
May want to check your bulb. They only last 3or4 years
1/8/2015 9:52:32 AM • Mitsubishi... • Answered on Jan 08, 2015
Tv powers on intermittently when the power button is pushed. When it does the tv has sound but no picture.
Hello, first off the set was last made in 2006, so it's 8 years old. Have you checked to see if the lamp is bad? Disregard "Houndog101"'s remarks, they are for an older crt projection tv. If the lamp is ok, it may be the color wheel has failed, a power supply or a bad ballast board, but my first guess would be the lamp part number 915P027010. Let me know what you find on the lamp.....tks
10/5/2014 6:52:39 AM • Mitsubishi... • Answered on Oct 05, 2014
5answers
Problems with mitsubishi WD 65737
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
8/24/2014 2:42:14 AM • Mitsubishi... • Answered on Aug 24, 2014
Mitsubishi WD-73827 73" HDTV DLP TV Logo
303 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
seem very little brightness even when
  • Televison & Video
