20 Most Recent NEC VT595 LCD Projector Questions & Answers
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
NEC VT595 LCD... | Answered on Jun 22, 2019
press and hold help button for 10 sec..
NEC VT595 LCD... | Answered on Dec 08, 2014
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
NEC VT595 LCD... | Answered on Jul 14, 2014
I have had the same problem with my NEC VT695, however, while trying to repair it, I actually broke off two pieces, first the arm that is attached to the lamp cover that depresses the button, and then the actual button itself. Does anyone know any way to bypass this need to have the lamp cover seated 'properly'?
NEC VT595 LCD... | Answered on Mar 04, 2014
It is a skilled work. If you wish to get more details about this kind of work, check this link. Pull up older posts there.
NEC VT595 LCD... | Answered on Mar 21, 2013
VT 595 the focus knob won't turn appears frozen other then that it works well
NEC VT595 LCD... | Answered on Nov 29, 2012
You'll need the remote control of the projector. On the remote, press the HELP button and hold down for 10 seconds.
NEC VT595 LCD... | Answered on Oct 15, 2012
if Power is flashing orange - then it's cooling down
if Status is flashing red - then there are 4 flash combinations.
1 cycle (0.5sec On, 2.5sec Off) lamp cover or housing error
2 cycle (0.5sec On, 0.5sec Off) temperature error
4 cycle (0.5sec On, 0.5sec Off) fan(s) error
6 cycle (0.5sec On, 0.5sec Off) lamp error
Which is your condition?
NEC VT595 LCD... | Answered on Sep 06, 2012
Check your owners manual for diagnostics. You can find all documentation for your VT595/695 projector on the NEC support site.
The users guide indicates that the lamp timer needs to be reset. Instructions can be found on page 49 of the users guide.
Press and hold the HELP button on the remote control for 10 seconds to reset the timer.
NEC VT595 LCD... | Answered on Aug 16, 2012
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
NEC VT595 LCD... | Answered on May 23, 2012
NEC VT595 LCD Projector Logo
58 questions posted
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • NEC Office Equipment & Supplies
Most Popular Question
will not turn thus not focus zoom
  • Office Equipment & Supplies
