HP Compaq d530c PC Desktop Logo
Anonymous Posted on Dec 13, 2011
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
  • Anonymous Dec 14, 2011
    Thanks for your advice. The power supply fan does not spin, but the LED still flashes 4 times.
Duane Wong
Level 3:
  • HP Master 6,826 Answers
  • Posted on Dec 13, 2011
Duane Wong
HP Master
Level 3:
Answers
6826
Questions
6
Helped
2862274
Points
20234
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
TV comes on to standby, but with record led flashing. pressing power on , power light turns green for 1 second, click from within unit, back to standby with record led flashing
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (a couple of hours).
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
1helpful
Samsung PS51D550C1M plasma tv loads Samsung page and turns off, LED flashes 4 times and repeats process again? The led flickers when the remote is used but nothing happens? Thanks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
I have sony tv model KV-HA21M80 is having problem front stand by L.E.D is blinking 4 times and stopping. for that power start I.C has been changed. But still same problem. could you pls give any solut
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Wd5000g032 001
when you get a fault with a lot of computers the computer will flash in a set pattern so you know what the fault is.
what make is your computer?
the link below is for hp computers
every manufacturer will have a list on their website
some computers blink and some beep.
you have to count the led blink code, the blinks will be something like 2 fast blinks and 2 slow blinks
look at this page to give you an idea of what i mean.
if you don't have an hp a google search will show you what you need for instance type "acer led blink codes" or "asus led blink codes"
https://support.hp.com/gb-en/document/c01732674
good luck
i hope this helps
Tv 2000 xp
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Hi, the lights on my circiut board are flashing the one on the left is on all the time and the one to the right of it flashes two times and then waits and then flashes two times again
Error Codes
A green LED indicates system faults
Steady On: System OK
Steady OFF: Board control fault or no power applied
1 Flash: Ignition failure (control in one-hour lockout)
2 Flashes: Pressure switch fault, fails open (switch is
stuck open)
3 Flashes: Limit switch open (main or auxiliary)
4 Flashes: Pressure switch fault, fails closed (switch is
stuck closed)
A yellow LED indicates flame status
Steady on: Normal flame is sensed
Flashes: As flame weakens, frequency of LED flashes
increases
hope this is helpful.
2answers
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
2answers
Light are flashing
Can you tell me exactly how the lights are flashing. This flashing is a code that will tell me whats wrong witht he printer.
Thanks,
Brad Nelson
1helpful
HP compaq d530c timer running fast
you may check and see if it's set to the "internet time" -> "automatically syncronize with an internet time server", if there you have a wrong server, then it'll reset your time wrong, or if you have another timezone set in windows, than it'll update to that timezone.
secondly, if it's a hardware related issue, than it can be the battery
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
