20 Most Recent Ruud Central System Air Conditioner Questions & Answers
4answers
Why is the outside air conditioner unit not turning on
Could be a bad capacitor.
9/8/2019 4:52:21 AM • Ruud Central... • Answered on Sep 08, 2019
I need fan blades for model # UACG-024JAS
Sorry we do not sell parts nor have any way to locate them for you.
6/8/2018 7:43:17 PM • Ruud Central... • Answered on Jun 08, 2018
0answers
I NEED A RELAY
Check grainger.com or repairclinic.com
9/20/2017 2:41:10 PM • Ruud Central... • Answered on Sep 20, 2017
How do I reset preset programs on my thermostat? I do not want any programs set. I want to manually adjust temperatures on my own.
Get a users manual from website, download, and use it to reprogram the thermostat.
12/1/2015 8:23:40 PM • Ruud Central... • Answered on Dec 01, 2015
NEED TO REPLACE PLYWOOD SUPPORT FOR RUUD AIR
put blocks under 4 corners work small sections at a time.
8/17/2015 9:18:35 PM • Ruud Central... • Answered on Aug 17, 2015
Rudd rhll-hm3821ja
sounds like low on freon.
8/17/2015 4:49:28 PM • Ruud Central... • Answered on Aug 17, 2015
How do i clean the outside unit
turh off power & use water hose to wash condensor coil. stay away from power panel of unit let it set for 4 hours turn power back on restart.
8/17/2015 4:23:11 PM • Ruud Central... • Answered on Aug 17, 2015
Burners turn on for 10 sec and shut off
going out on safety. either high limit or failure to detect flame.
8/17/2015 4:03:00 PM • Ruud Central... • Answered on Aug 17, 2015
Ruud a/c, fan works but no cold air.
if the outside fan is running you have correct voltage. compressor capacitors could be bad.
8/17/2015 3:56:58 PM • Ruud Central... • Answered on Aug 17, 2015
When should you use emergency heat with a heat pump
when outside temperture gets to low for heat pump to work effiencely
8/12/2015 9:29:15 PM • Ruud Central... • Answered on Aug 12, 2015
Nodyne heater relay making buzzing noise
relay needs to be changed. you could probably tap on it & it would quit..
8/11/2015 3:08:28 PM • Ruud Central... • Answered on Aug 11, 2015
Electric heater blows cool air unless i turn the thremostat up at least 5 degrees higherthen it goes to high and blows warm air
thermostat neeeds to be calibrated or one of your 1st stage heating elements bad.
8/11/2015 2:58:09 PM • Ruud Central... • Answered on Aug 11, 2015
How do I clean a coleman heat/air conditioner
outside unit spray with garden hose. start at top of the grill, work ur way down. u will see dirt come out of bottom.
4/1/2015 7:15:57 PM • Ruud Central... • Answered on Apr 01, 2015
No cold air
sounds like you need a new contactor but check to make sure you have 24v at the control wiring side of the contactor first. If you don't have 24v check the condenser low voltage wiring and the thermostat wiring.
3/19/2015 10:01:24 PM • Ruud Central... • Answered on Mar 19, 2015
R-22 home condenser unit low side and high side pressures when running
Pressures look good but to know if it is charged correctly you have to do a sub cool or superheat to know for sure. Rule of thumb is if turn unit it on let it run 10 minutes. If the suction line sweats and is cold. Might be proper charge. If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_70df8fb57a5e233e
2/24/2015 12:33:42 PM • Ruud Central... • Answered on Feb 24, 2015
Fixya how to find serial no. for
It's inside the unit on the left wall
2/12/2015 4:06:53 AM • Ruud Central... • Answered on Feb 12, 2015
5answers
What's the difference between EM HEAT and AUX HEAT?
Sorry, neither of these answers are completely correct.
You have a heat pump (or the wrong thermostat). Let's assume you have a heat pump.
In air conditioning mode, it works like every air conditioner you have ever had, but...
In heat mode, it reverses its operation. Have you ever felt the air coming out of the outdoor unit of your A/C unit? It's hot, isn't it. And the air coming out of the indoor unit (out of the registers) is cold. Now for a heat pump to produce heat it simply runs the air conditioner in reverse and the heat comes out in the house and the cold is released outside. Neat, huh!
Here's the problem with heat pumps...when it is really cold outside the heat pump can't produce enough heat to heat your home. So it has an additional heat source called "Auxiliary Heat". This heat comes on automatically when the house doesn't get warm enough. The source of this heat is based on the region of the country you are in. North/Northeast generally have oil heat, other regions have gas, and still others have to use electricity to heat. In Texas, we usually use electricity as the supplementary heat on heat pumps. VERY EXPENSIVE!
Now the "Emergency Heat"...this is exactly as stated in Solution #2. This is manually turned on by YOU at the thermostat when your heat pump fails. This turns on the auxilliary heaters and turns off the heat pump (remember, the reverse air conditioner). Again, this can be quite expensive to run if your heat source uses electricity! Gas and oil may be cheaper. The emergency heat is only designed (normally) to keep the house livable (not comfortable) until the Heating Tech can get out to you and fix your heat pump.
Something else you should know. It is normal for a heat pump's outdoor coil to frost up during heating mode. It will detect this and go into DEFROST mode and melt the frost off the coil. While it is doing this, it will turn on the auxilliary heater to keep the air blowing in the house at a reasonable "warm" temperature, but it will not be as hot as normal. In fact, heat pumps produce a lower temperature heat than traditional heaters. So the air may feel cooler during heating than you are use to anyway. This is normal and is not a sign of a problem.
So what do you do: Set your thermostat to the temperature you want and set the controls for HEAT/COOL and FAN-AUTO/ON and leave the EMERG HEAT off unless your heat pump breaks.
As always, keep your filters clean and your outdoor unit's coils clean and free of debris.
Hope this explains your question for you!
2/9/2015 9:47:42 PM • Ruud Central... • Answered on Feb 09, 2015
Ruud Central System Air Conditioner Logo
288 questions posted
Top Ruud Heating & Cooling Experts
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Ruud Heating & Cooling
Most Popular Question
find electrical diagram split condionner
  • Heating & Cooling
