Cars & Trucks Logo
Anonymous Posted on Dec 10, 2011
Where are the spark plugs 04 proton waja 1.6
I can not find the spark plugs or leads on my 04 proton waja it has a 1.6 mitsubishi engine
Leo Rottering
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 10, 2011
Leo Rottering
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
644
Points
If it is like my 4 banger '99 MB, remove the "panel" from on top of your engine
1helpful
My proton jumbuck won't start what can be the problem... can it be the computer box
It certainly could be, but I wouldn't jump to that conclusion so quickly. Leave such diagnosis' to the pros, who often zero in on the most expensive component without proper troubleshooting.
Typically, troubleshooting would start with seeing if you can get a spark at the spark plug. Then work back from that (assuming the starter is turning the engine over properly). This means spark plug, leads, disributor cap, distributor rotor, electrical continuity to the distributor and coil. About the last thing on the list is the (expensive) ECU.
I own a Proton waja 1.6 a/t.2006 some time I have both light blinking at D and N the car is running at 3rd gear every time the D&N light appear.
Get it scanned. A proper scanner would show what is wrong. A few probable causes, namely speed sensors, AT position switch, wire harness and eventually TCM.
Have just replaced plugs and leads and the engine light keeps coming on for 1 to 3 mins and when its warm and i go to start it again the engine light comes on and runs a little rough what could this be?
It must be from the rough idling. Check the spark plug gaps and the lead wires if they have good continuity. Check your car manual for the proper gap for the spark plugs. Set it with the use of a spark plug gauge.
Proton waja immobilizer
test the ignition coil see the instruction attached AND fix it.
God bless you2905aaac-86a9-4506-abfb-42f1e01a897a.jpg7b3ec7f3-4775-4f58-83be-65f24e821612.jpg13fa820c-74a4-43bf-b639-0d6a0ce7b153.jpg3b0a633a-9d94-4249-8088-948557d4f8a7.jpg88fe77db-b163-4618-8c6c-7ec518ecae94.jpgbd6aed0c-0d33-4efd-80d8-9c1d2558c526.jpg
FIRING ORDER PROTON JUMBUCK
If it's 4 cylinders, it's 1-3-4-2. for Mitsubishi/Proton engines.
1helpful
Wiring diagram of proton waja
saya sedang mencari sesiapa yg nak menukar enjin auto kereta waja ke enjin manual..
Sesiapa berminat sila hubungi saya di 010-9090 767
04 mitsubishi galant won't start..started off
Sounds like your Timing Chain or Belt Are Damaged and Caused your Ignition Timing to Jump out of Time, Also check your Distributor Cap and rotor NOTE: if you have a Distributor ,Some are Distributorless. Pull your Spark Plugs out BEFORE you Do Locate #1 Plug its in Front of your Engine.And Trace the Wire to the Distributor Cap. If you have a 4 Cylinder #1 is in the First Plug in front of vehicle, if its a V-6 #1 Plug is on Left side first plug in Front. Depending on which engine you have will determine if your wires go into the Distributor cap Clockwise or Counter Clockwise. So BEST to Simply Mark them to get them back in same order.You'll need to Get the Enging to crank over and have a Buddy Put a Compression Gauge in #1 Cylinder and Bring it up to TDC (Top Dead Center) thats when the piston is up and gets the Gauge to Move up then your on the Compression Stroke, Then check distributor rotor to see if its pointed to where your #1 Spark Plug wire came off or at least close to it.Just hit the Ignition Switch off and on Until you have it showing compression on Gauge. JUST ON and OFF that Fast. If the Rotor is pointing To a different Spark Plug Wire in the Cap, Sounds like timing Jumped. Hope this will help you solve your problem or at least find it. If you don't have or not sure on How to do this i recommend you have a Qualified Mechanic Shop run the Tests. Thanks and Good Luck
1helpful
I was driving when my engine just stoped i tryed to start it but it wont start the engine will turn over but it just wont start
it is possible the points in the distributer cap have failed, or worn. check your spark plugs (you will need 2 people for this) or even just your leads by having one person turn the engine over and the other holding 1 lead (just take one off at a time) against the engine block it should throw a spark and arc to the block ******DONT TOUCH THE SPARK IT HURTS****** if you dont get a spark then it is most likly a distributer problem. Hope thes helps
I have a proton waja 1.8,after replace ecu,can not start up the engine
Dear sir, if you change the ecu, u need to reset the combra cable, this seting only can done by proton service center, because it combra cable got the coding inside you need to reset it. anything email to me at [email protected] by.. joseph
2helpful
Change spark plug wires on 04 kia sedona
REMOVAL OF THE PLUGS:
Do not attempt any maintenance on spark plug if engine is hot.
1. Disconnect negative battery terminal.
2. Carefully remove high-tension leads.
3. Use compressed air to blow any dirt or debris from around spark plug hole.
4. Check that spark plug fits squarely in spark plug socket and remove spark plug.
Raise a vehicle and install SST(OK552 131 001) in order to replace cylinder 2, 4, 6 spark plug.
INSTALLATION:
1. Install spark plug into cylinder head.
Tightening torque : 18~22lb-ft (25~30N·m, 2.5~3.0kg-m)
2. Reconnect high-tension leads.
3. Reconnect negative battery cable.
Hope this helps and simple to understand. Good luck
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
