HI.your problem seems not explain properly including the unit name,the type of the machine.you may s well describe it so that we can find solution on it.thanks.
What type of PA speaker are you using? what OHM? and wattage.. A cb pa can only supply MAX 5watts into a pa speaker. It may be too big of speaker or bad speaker? if it works on cb.. wrong OHMS can make problems too..
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. But, if you've checked the slide switch, the internal switch in the card slot may be jammed by a grain of sand or gunk. Here are troubleshooting steps for this problem. Recommend the toothpick fix for your particular problem.
You might want to check and make sure the battery is still good. If you purchased the camera used and didn't change the battery then this might be the case.
But in the mean time this is what you need to do: 1st-make sure that the shutter speed dial is set to any shutter speed other than the red circle w/red ring. If your camera is set to that it will drain your battery when not in use since it is designed to be an automatic setting. I set mine to 1/125th to do this push in the circular dial on the side and at the same time turn the knob.
2nd- locate the 2 levers on the opposite side of the shutter speed dial. Once you found them then position the back lever all the way forward towards the setting for "MULTI" and position the lever towards the front straight up.
3rd- then wind the film crank till it won't wind anymore and depress the shutter, if it is wound and the shutter release is still stuck then skip to the fourth step, if something happened and you heard a click then still proceed to the next step because no the shutter release will be temporarily stuck.
4th-Once both of these levers are in this position there should be a red
button just behind the shutter release button on the top right side of
the camera.... drum roll please...."Push the red button" what you
should hear is a rather loud click, this click is the mirror releasing allowing you to: 1 wind the film crank and take another picture and 2 this also now allows you to see through the lens again (assuming that you have a lens on the camera).
In Conclusion: without a battery that is fully functional in the camera this is how the camera will operate once you get a battery for your camera then reposition the levers on the side of the camera opposite of what I suggested (this will be the normal operating mode for the camera with a battery) then when you wind the film crank and depress the shutter everything will function normally.
You have to place your foot on the brake before the lever can be released out of the park position . If this does n't work have a look and see if the brake lights are working when depressing the brake pedal . If the brake lights don't function , replace the brake light operating switch which is located just behind the brake pedal .
Tip : note the distance the old switch is adjusted in relation to the brake pedal before you remove it and adjust the new one to the same distance .
This is the most common cause of the problem you have described .
It sounds like your power on button may be stuck, if the ON indicator is always on. That may be the reason your battery was dead yesterday. Try reinstalling your batteries, checking carefully the positive and negative positions, and working your power button several times rapidly to see if it is stuck. If it is still showing a constant ON condition, try the following steps. With the batteries out of the camera, try a tiny bit of rubbing alcohol around the power switch, working the switch rapidly for a few seconds to see if that frees it. Replace the batteries with knownfresh ones and try to power up the camera. That may fix your problem. If not, the camera will probably have to be repaired or replaced.
Check the batteries first. The electromagnetic shutter requires power to function. To free up the shutter and advance lever, rotate the command switch to "M90" (if I recall). That should re-set the shutter and allow you to advance the lever mechanically.
You are correct that the switch locks the aperture. In order for your camera to function correctly in the auto-focus mode you must lock the aperture to the smallest opening (largest number such as f22). The switch has two positions. The position where the switch is lined up with the orange line is the locked position. When the lens functions properly and on the camera, the lens aperture is forced wide open by a pin on the camera body pushing a lever on the lens that opens the aperture. As part of the sequence when you push the shutter button, the camera releases its pressure on the spring-loaded lever on the lens, allowing the aperture to close to the setting that the "computer" has determined as correct. You will find this lever on the outside of the black ring that surrounds the rear lens element. With the lens removed, find the lever and make sure that with the lens set to the f22, sliding the lever counter-clockwise against the slight spring tension, the aperture opens wide and returns to f22 when released. If this is not the case, the problem is in the lens. If this works, then the problem is either in your camera body or in the alignment between the body and lens. If this does not get you on the right track, let me know what you find and we will proceed from there.
The small nylon power button contact lever breaks easily on these camera. For those of you that are capable you can try to repair the lever but I have found this to be quite difficult and usually breaks after the fact. This requires opening up the unit and removing the dark grey L-shaped button piece and then repairing it. But, for those of you that just want to get the camera working again quickly with just a little inconvenience follow these instructions.
Drill a small hole in the top of the camera as indicated in the picture here. It will be right on top of the circuit board button cotact for the Power button. Just use a paper clip and stick it into the hole and depress it once to turn the camera ON. Same for turning in back OFF. Easy fix.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Yes, this camera has an auto power save function to save power.The camera turns off the displays and unnecessary functions if an operation is not made within a minute. (Power Save Function).To restore the power, press any button or key, or turn the exposure mode dial to another position.The length of this period is selectable from 1 min., 3 min., 5 min., or 10 min. in the section 1 of the setup menu.The LCD monitor always turns off if any operation is not made in a minute, and this period cannot be changed.If no operation is done within 30 minutes, the camera shuts itself off. Pressing the power button resumes the camera operation from this condition.
