20 Most Recent Sony Cyber-shot DSC-S600 Digital Camera Questions & Answers
Problem for Sony Cyber-shot DSC-S600 Digital
Its Lens Block Assy is faulty. Below is part no of Lens yey4u7iqvnoaaaaasuvork5cyii= Problem will solved after replacing Lens assy Kind regards.
10/18/2017 9:38:14 AM • Sony Cyber-shot... • Answered on Oct 18, 2017
My Sony Cyber-shot DSC-S600 stopped working. I
Remove the batteries and SD card, leave the battery door open, and put the camera in a jar along with a dessicant bag or a small bag of uncooked rice that has been opened. Put the lid on the jar and let it sit for a day or so. This should absorb any condensation inside the camera that may be keeping it from working properly.
7/2/2017 11:20:32 PM • Sony Cyber-shot... • Answered on Jul 02, 2017
5answers
Error code E:61:20 on Sony DSC-S600
This is the result of the gears in the viewfinder that run a barrel style gear are misaligned or mashing.
Two Solutions:
1. Replace or clean out and reseat the gears of the viewfinder. This requires a small bit of technical camera repair expertise.
2. Now do not laugh at this one. Turn the camera ON and immediately while the grinding is going on slap the camera very hard in the palm of your other hand. Do this repeatedly until the issue fixes itself. I have recommended and done this many many times and fixed a bunch of cameras this way. LOL The gears of the motor and the viewfinder barrel gear become misaligned so a good hard jolt seems to get them back in alignment and you should be good to go.
Good luck. Stop the laughing it works. LOL
10/5/2016 10:23:53 AM • Sony Cyber-shot... • Answered on Oct 05, 2016
DSC-S600 , THERE IS NO RESET BUTTON OUT SIDE
Camera is damaged, needs professional repair.
4/23/2016 12:34:32 PM • Sony Cyber-shot... • Answered on Apr 23, 2016
Keeps saying low battery but
Your camera is a power hog. Try using the new high power battteries. Ther are expensive but generally work in this situation. There could also be a problem with the camera, I can't rule that out.
BonDE
8/4/2014 5:59:58 AM • Sony Cyber-shot... • Answered on Aug 04, 2014
Everything works on the screen but the shutter
The shutter needs to be cleaned with a qtip and alcholl.also batteries might need charging .
10/15/2013 9:46:49 AM • Sony Cyber-shot... • Answered on Oct 15, 2013
0answers
2answers
Lens cover stuck DSC600
You may have the same problem that i had. It does involve taking the camera apart. Not overly difficult - just fiddly.
Let me know and i'll talk you thro' it
1/21/2013 4:56:39 PM • Sony Cyber-shot... • Answered on Jan 21, 2013
3answers
Lens cover stuck
im having the same prob with mine right now. my little sister had it for a while and she said it started doin it ramdomly but now the lens wont close at all
4/15/2012 9:23:51 PM • Sony Cyber-shot... • Answered on Apr 15, 2012
How do you delete photos from Camera after you have downloaded and saved to PC? (Apart from delteing one at a time?
When you are connected to the PC the camera should look like another drive on your computer. Usually E: or F: open it up find the pictures, highlight the ones you want to delete and press delete or drag them to the recycle bin.
12/26/2011 4:06:52 AM • Sony Cyber-shot... • Answered on Dec 26, 2011
The camera won't stay powered on. Battery is new.
thanks, problem solved!
9/24/2011 6:41:21 PM • Sony Cyber-shot... • Answered on Sep 24, 2011
My camera fall and it
Since you dropped your camera there is chance that circuit board will be malfunctioning .
First of all try to reset the system. Most of time this will fix the problem..
To reset, please Switch off and remove the battery and then after 20 minutes insert new batteries and now switch on the camera .
If the reset doesnt help then surely the problem is with the circuit board. Most of time some capacitors goes shorted or get fused because of high electric supply to the unit.
It is risk to do -it-yourself , take to authorized service center to get it repaired from technician .
Hope this helps .
Shane
9/4/2011 8:24:41 PM • Sony Cyber-shot... • Answered on Sep 04, 2011
How can i download newly
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
8/20/2011 2:44:46 PM • Sony Cyber-shot... • Answered on Aug 20, 2011
The power button in my
Hi, Your best bet would be to find one on ebay or kijiji where someone is selling that model of camera for parts. Unfortunately any of the companies that I can usually find parts from don't have the button for sale so that'd be your best bet.
7/31/2011 1:14:17 AM • Sony Cyber-shot... • Answered on Jul 31, 2011
I uploaded pictures from my
Hi,Unless you FORMATTED the memory card when it is in the camera thru your camera
MENU pictures should be there..
To find out that either connect the camera to computer or take the card out and insert the card reader slot of your laptop (if not you may need Memory Card Reader " THAT COMPATIBLE WITH YOUR MEMORY CARD.This card reader facilities TO DOWNLOAD YOUR PHOTOS/VIDEOS to PC too....As an example of this unit pls visit the URL below....you can buy it any electronic Market too..) and to see if the pictures are still there..if you have erased them and you still want to recover them you need to download a RECOVERY program to ypur PC.,If you need more help ,Let me know the result...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
26-IN-1 USB 2.0 MEMORY CARD READER FOR CF/xD/SD/MS/SDHC
http://cgi.ebay.com/26-IN-1-USB-2-0-MEMORY-CARD-READER-CF-xD-SD-MS-SDHC-/290583009260?pt=PCC_Drives_Storage_Internal&hash=item43a818d7ec
7/13/2011 7:50:08 PM • Sony Cyber-shot... • Answered on Jul 13, 2011
We're trying to see if
I understand that you're not getting sound on the recorded videos when playing it in the Camera itself. Unfortunately, due to the bad design, the Camera does not have a built in speaker to generate sound when playing videos in it. It is required to connect the Camera to a TV or transfer the recorded videos to Computer to hear the audio on the videos.
This is a common issue with DSC S Series Sony Cameras.
Thanks for understanding. Please let me know if you require any clarifications.
6/27/2011 4:03:10 AM • Sony Cyber-shot... • Answered on Jun 27, 2011
Power button stuck down on
Possible that this is a mechanical failure and the switch is broken or out of place. Remove the battery and check the charge, if this seems fine then replace and tap the camera upside to see if the buttons resets.
If not the camera must be taken out, try to open ONLY if you have the correct tools and do not try to open otherwise to damage the unit.
Best option is to take an opinion from Sony for estimation.
6/25/2011 12:00:21 PM • Sony Cyber-shot... • Answered on Jun 25, 2011
Sony Cyber-shot DSC-S600 Digital Camera Logo
253 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
error code e 61 20 sony dsc s600
  • Cameras
