SC542:Fusing Temperature Warming-up Error. Definition [A] ..... The settings that are required for image processing using the printer controller
the fusing temperature does not reach fusing standby temperature within 6min after the main power switch is turn on or after closing the front door
the probable causes are
check the fusing thermistor it may be defective or out of position
fusing lamp open,fusing thermofuse open the BCU may be defective check the ac drive board it may be defective ,check also the fusing unit connection there may be loose end
Hope this helps appreciate by rating it
SC542: Fusing Temperature Warming-up Error
Definition [A]
The fusing temperature does not reach the fusing standby temperature within 6
minutes after the main power switch is turned on, or after the front doors are
closed.
Possible Causes
· Fusing thermistor defective or out of position
· Fusing lamp open
· Fusing thermofuse open
· BCU defective
· AC drive board defective
· Poor fusing unit connection
Definition [A]
closed.
Possible Causes
· Fusing lamp open
· BCU defective
Thanks for the info. care to try again?
