20 Most Recent Gestetner 2212 Digital Imaging System Copier Questions & Answers
0answers
Lost password for gestetner copier
if its just your machine then reset All by entering the service mode then mode then clear enter then clear engine if it faults then clear All
11/19/2015 12:28:06 PM • Gestetner 2212... • Answered on Nov 19, 2015
Gestetner DSM730
thermostatic from the fuse unit
11/19/2015 12:19:10 PM • Gestetner 2212... • Answered on Nov 19, 2015
0answers
Error sc 542
Be the first to answer 11/20/2013 3:01:07 AM • Gestetner 2212... • Posted on Nov 20, 2013Be the first to answer
3answers
Service Code - Fucntion Problem
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
9/11/2013 7:14:45 AM • Gestetner 2212... • Answered on Sep 11, 2013
4answers
I have a Gestetner 2212
If you're worried about Windows 7 drivers you can get them here.
I suggest you put a page into the scanner part of the Gestetner 2212, press the scan button and see what happens. It might just scan and then automatically print, or want to save it to your systems hard drive.
9/13/2011 1:19:42 AM • Gestetner 2212... • Answered on Sep 13, 2011
My copier makes crooked copies gestetner 2212
check that the end fences are up against the paper in all the trays.
7/28/2011 6:40:26 AM • Gestetner 2212... • Answered on Jul 28, 2011
My printer when printing from feeder makes crooked
Most likely the Hinge screws have become loose and the feeder is out of alignment. Make a copy on the platen glass, if it comes out straight then it is definitely a misaligned feeder. Hope this helps.
7/21/2011 1:12:42 AM • Gestetner 2212... • Answered on Jul 21, 2011
I want to set up
Hello.
Follow this steps:
- Press User tools/counter
- Press system settings
- Press the tab Interface settings
After that you will see the options to change the ip address; gatway; sub-net mask...
Hope this helps you.
See you!
7/15/2011 12:57:14 PM • Gestetner 2212... • Answered on Jul 15, 2011
Does a Gestetner 2212 work
If your device cames with PS, yes you can.
With MacOs You need Post Script to print with any printer. I know that the latest versions of Mac already print with PCL. I can not tell you if your version is the latest.
Although you can take a look on this web site http://gimp-print.sourceforge.net/MacOSX.php.
See you!
6/5/2011 12:02:59 AM • Gestetner 2212... • Answered on Jun 05, 2011
2answers
I am considering buying a
Since the item is 8 years old I would not recommend the purchase, most units last 3 to 5 years on the average and the machine has already exceeded that time frame. Plus it is unlikely it will work with the Mac because the printer is to old.
6/4/2011 8:35:05 PM • Gestetner 2212... • Answered on Jun 04, 2011
Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
3/1/2011 12:48:41 AM • Gestetner 2212... • Answered on Mar 01, 2011
Gestetner 2212 error codes
what is your error code
1/19/2011 6:26:41 AM • Gestetner 2212... • Answered on Jan 19, 2011
Error code sc542 happened right
Sc 542: is fusing problem.
perform the following proceder to solve this problem:-
press Clear all __107__clear (hold clear for 5 second )
press 5 __ R __ 810 __ R __ print
turn off on.
1/17/2011 2:42:37 PM • Gestetner 2212... • Answered on Jan 17, 2011
I have a Gestetner 2212 here at the office and it
yes... either the network cable got unplugged from teh copier or you have an ip conflict... here is how to tell... if you have an ip confilict... unplug the network cable from your pc... print a network status page or go into the print driver and pull the ip address from it and then, on your pc, press start, accessories, command prompt and then type ping and type in copier's ip address then press enter... it should look like this ping 192.168.168.168 if you don't get four time outs... then you have an ip conflict and you need to change the ip address of the copier to one thats not in your ip range... generally thats a low ip address...something that ends in a number less than 100 I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
12/9/2009 7:43:23 PM • Gestetner 2212... • Answered on Dec 09, 2009
The display says following output tray is full.
Look at the area where the paper just exits from the machine. You should see a small black plastic arm. Make sure it has not become stuck in the up position or knocked out of place. This arm is what tells the machine that the area is full of paper. Also your machine is the same as Ricoh 1022, Savin 2522 in case you need to do more research.
10/19/2009 1:05:18 PM • Gestetner 2212... • Answered on Oct 19, 2009
GESTETNER 2212 WILL FAX OUT BUT NOT IN
Make sure that the phone cord is plugged into "line" and not "phone" You can also check by pressing "on hook" button to see if you get a dial tone. Also, Call the fax number to see if the machine is trying to receive.....you should get high pitched, varying tones (hand shake is what they call it) this will let you know if the fax part is talking to phone line.
7/4/2009 11:45:07 AM • Gestetner 2212... • Answered on Jul 04, 2009
Gestetner 2212
Go to; Gestetnerusa.com -- click on the 'support & drivers' tab --- insert/ select your machine -- then select your OS (operating system) and dowload.
1/14/2009 7:47:26 PM • Gestetner 2212... • Answered on Jan 14, 2009
23 questions posted
Top Gestetner Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
ZJ Limited
ZJ Limited
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Gestetner Office Equipment & Supplies
Most Popular Question
gestetner 2212 copier service code sc542
  • Office Equipment & Supplies
