20 Most Recent
Ricoh Aficio 3025 All-In-One Laser Printer Questions & Answers
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
- B205-0153
- that depends on the counter number.
- or the cap from the other toner is still inside the the toner holder.
- check the old toner bottle does have a cap on it.
- how ever for i need the print counter to see if the PCU is for replacement.
- write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
- please write some additional info.
- Best Reagrds
How do I select A3 paper from the menu of the
You can only select a paper size from the operation panel that the machine has loaded in the paper trays. If your are trying to select A3 and A3 does not show up in the list of available paper sizes then either you do not have that size loaded or the paper size dial in the tray is not set properly. These Ricoh's use a paper size dial in each tray that is designed to tell the machine what paper you have placed in that tray. So it is somewhat common for me to hear from people who have this problem because the paper was changed without changing the dial or the dial has been accidentally moved. I would check the paper size dial in each tray to be sure it is correct.
If I have not answered your question correctly please provide more specific info as to your situation.
Thank You for using Fixya.
WheatlandServices
Ricoh sp3510
As in a toner empty error? Otherwise, it needs a new PCU.
Ricoh aficio 3025
Go get the firmware from the ricoh site. Get the rfu file if you are doing it remotely eg. from your laptop or PC. Just make sure nobody is using the printer while you are doing it.
How to solve richo problem if it says used toner botle is full?
Please use caution in following the steps above. It is very important if you do not want to expose yourself to airborne toner that you are very careful about what type of vacuum cleaner you use. Many vacuums do not have filters fine enough to capture the toner and it gets blown out into the air where you breathe it in. This is the reason that technicians will be equiped with a small black suitcase vacuum. 90% of that suitcase is filter that traps all the toner.
