Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
Anonymous Posted on Oct 06, 2011
"there is a problem with the printhead"
Peter
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 25, 2014
Peter
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5307
Points
12
Sounds like you need a new one. The best place to buy is amazon (because of reviews and price). take a look Lexmark Printhead cheers
  • Official Brand Answer 3,344 Answers
  • Posted on Dec 29, 2011
Anonymous
Level 0:
Answers
3344
Questions
0
Helped
923803
Points
5508
A firmware update for the Lexmark Prospect Pro205 will help fix the printhead issue you are experiencing. Please follow the steps below on how to successfully update your printer:
  1. Open the printer cover and remove the printhead and tanks (if installed). Note: Carrier will come to the center automatically with this error message as the cover is opened. Remove the ink tanks > open the printhead latch and remove the printhead > close the printhead latch, close the printer cover and confirm the error message goes away from the operator panel.
  2. Proceed with the firmware update. Please visit the Lexmark website to download and install the Lexmark Pro200 Series Firmware Update.
After successfully updating your printer, open the printer cover > re-insert the printhead > close the printer cover. If no printhead error comes up, continue with normal installation steps for cartridges. If error comes up again, please contact Lexmark Technical Support Center for further assistance.
  • Anonymous Dec 29, 2011
Error code e02826 after installing new printhead
Reset the print head. While out clean terminals with damp cotton wool. Should start after that if not probably faulty printhead,
Indicator says "Printhead Problem". The
You do not say what your make and model is. So follow the screen prompt and replace the black/yellow print head.
3helpful
I have a lexmark prospect pro 200 series printer and there is an error message that reads "There is a problem with the printhead. Please consult User's Guide."
Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps: 1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center. 2. Once you have the printhead removed, close the cover of the printer and turn on the printer. 3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button. 4. It should take you back to the "Copy" menu. 5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first. 6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
Source: There is a Problem with the Printhead
Message:" There is a problem with the printhead.
Make sure your printer is updated. The firmware update, available in the Lexmark website, will help fix printhead-related problems. Follow these steps: 1. Remove the printhead from the printer.
2. Reset the printer by unplugging the power adapter from the printer (should be the whole black box on the back of the printer), leave it unplugged for about a minute then plug it back in.
3. Once the printer is back on, it will ask for the printhead. Just disregard the message by pressing or CANCEL button on your printer screen. Do not install the printhead yet.
4. Then, please use this link: http://bit.ly/p705fw to download and run the firmware on your computer. Please make sure that the USB cable is attached from the printer to the computer while you do this.
5. Once the firmware update is complete, you may reinstall the printhead.
I've turned on my printer and it says " Error" "
Go to the Kodak site
Visit the page to download latest firmware
Install firmware
Printer says, "There is a
You could try to remove and reinsert the printhead.
Open the printer and lift the latch.
Wipe the printhead contacts with a lint-free cloth.
Reinsert the printhead.
If this does not correct the problem contact
Lexmark Priority Phone Support 1-800-395-4039
Printer: HP OfficejetPro L7680 ALL-IN-ONE immediately after a paper jam, my printer screen says "Printhead(s) problem. The Following printhead(s) has a problem. black/yellow (K/Y)" I do not...
hi!!
try to re-install the driver of your printer
and then try to unhook the cartridge and then
clean up the nozzle used alcohol and cotton buds
and then placed it back the cartridge correctly!!!
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
