Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
Anonymous Posted on Oct 05, 2011
Jucuzzi Espree aeroflo whirpool and air bath, LH model #DS75. The power button will not stay depress for on position. It will only work if the button is continually depressed.
2 Related Answers
Anonymous
  • 225 Answers
  • Posted on Mar 07, 2010
SOURCE: magic touch whirlpool switch won't stay on.
replace switch
boysor2933
Boyet Soriano
  • 293 Answers
  • Posted on Nov 06, 2012
SOURCE: Jacuzzi H546 won't stay on unless you press button continually
Try changing the motor relay.
2helpful
The air switch on my whirlpool tub will not toggle, i must hold the button in to keep motor running.
What you are experiencing when you push the Air Button down and it engages the BATH PUMP but when you release the the Air Button is a bad Air Switch in the BATH PUMP.
When you push the air button down it sends a column of air to move a small switch in the BATH PUMP. When the switch in the BATH PUMP is bad it will not engage.
What you need is a new Air Switch model TBS-339.
Rod
US Parts Center
888-521-6183
Feb 28, 2013 • Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jucuzzi Model U670 Espree 636 does not turn off after running. Have there been similar probelms reported and if it is the switch, can the switch be removed from the top?
Yes, I replaced mine from the top. It's fairly easy. You have to pop it out after you get the trim off carefully and then pull the air switch out remembering to get the 1/4 house to come out with the air switch so you can detach it and connect the new one.
1helpful
Hi, I am wanting to download and print out the installation manual for: Jacuzzi 60'L x 32"W x 22"H Espree 1-Person Hourglass Whirlpool Tub. I want to read this before I purchase this tub. ...
Hi Pat,
The installation manual should be available on this webpage but there seems to be a broken link when you try to download:
http://www.jacuzzi.com/baths/options/models/espree-6032#
You can e-mail Jacuzzi from the webpage and they should send the pdf install document out to you.
Hope this helps!
May 10, 2011 • Plumbing
1helpful
My temperture on my hydro bath seems to be faulty
TIME TO REPLACE SORRY TEMP GAUGE NOT BATH BEST OF LUCK
1helpful
2003 F250 Power Windows won't work
check fuses 35 & 41 (10 amp, red).
it also shows an accesory delay relay in the fuse panel.
And fuse 601? 30 amp.
make sure you don't have lock-out on driver switch panel activated.
Power Window System
Features and Operation
NOTE: The accessory delay feature will allow power window operation up to 10 minutes after the ignition is off or until a door is opened.
If equipped with power windows, the window control switch (14529):
  • will operate the power windows only when the ignition switch is in the RUN or ACC position.
  • is located on each front door trim panel, and Crew Cab and Excursion rear door trim panel.
  • may be used to raise or lower the driver side, passenger side and rear windows from the LF control on the driver side, or the passenger window from the passenger switch.
  • includes a one-touch down (OTD) feature for the driver door window.
  • can partially lower the driver side window when the LF window control switch is depressed half way (first detent).
  • will completely lower the driver side window when the LF window control switch is fully depressed and then released (second detent).
Power Window System — Modes of Operation
There are two modes of operation for the power window system.
Manual Mode
When the LH window control switch is pressed to the first down position, the window will move down until one of the following conditions are met:
  • The LH window control switch is no longer in the first down position.
  • The LH window control switch is pushed to the OTD position, causing the windows to enter auto mode.
Auto Mode
Auto mode provides the OTD feature. The OTD feature is activated when the LH window control switch, for the LH window, is pressed to the second down position.
Auto mode will be terminated when any of the following conditions are met:
  • The LH window control switch is pushed to the UP position.
  • The LH window control switch is released (OFF position) and then moved to the DOWN position (first detent) or OTD position (second detent).
  • Note: Delayed accessory feature must be active.
The OTD feature is controlled by the window control switch.
Condition Possible Sources Action
  • All power windows are inoperative
  • Fuse(s).
  • Circuitry.
  • LF window control switch.
  • Accessory delay relay.
1helpful
2answers
Air actuator button hard to push in.
the best plave for you to get a diagram is wholsey.. tell them name brand and size of your tub. and they should be able to help you.
1helpful
Kohler whirpool tub will not turn on
Here is the manual for the tub. The switch is an air switch with tube. You have to make sure the tube has no holes in it or replace it if you can. look on the manual it will help you out.
http://www.us.kohler.com/onlinecatalog/pdf/1010564_5.pdf
2helpful
3answers
Power button
This also helped me. Thanks
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
