ViewSonic VX2433WM 23.6" Monitor Logo
Anonymous Posted on Sep 28, 2011
I have a Vx2433WM and am using it as a tv for my PS3 through hdmi connection. The audio stopped working. I tried muting and un-muting but nothings happening. How do I get my audio back??
Level 3:
  • ViewSonic Master 17,130 Answers
  • Posted on Sep 28, 2011
ViewSonic Master
Level 3:
Answers
17130
Questions
0
Helped
3635791
Points
52372
First of all you must confirm if the fault is relative of the monitor or the PS3. So cross connect using a TV or another device to confirm the problem unit.
Once you have confirmed that the fault is with the monitor then switch off power and allow the set to power down and reset as it can be a fault with the processor which has hung up the source. If this wont solve then the monitor must be checked using a signal source to inject and infer so as to confirm the area of fault in the audio section..
Rofel Lantican
Level 3:
  • Master 2,632 Answers
Rofel Lantican
Master
Level 3:
Answers
2632
Questions
Helped
597549
Points
7882
Welcome to Fixya. If the volume is not working on the monitor the next thing you need to check is the HDMI cable. If possible to replace the cable so that we can determine the problem if this is caused by the cable, the monitor or the PS3. You can also try to connect the PS3 to a different TV using the same cable and see if you will hear a sound. Please let me know what happen so that we can continue troubleshooting.
Thanks
  • Anonymous Sep 28, 2011
    Had to select memory recall off the monitor menu. Not quite sure what was wrong but that fixed it.
  • Rofel Lantican
    Rofel Lantican Sep 28, 2011
    i see incase you have problem just let us know. Thanks for using Fixya
1 Related Answer
Anonymous
  • 2229 Answers
  • Posted on Oct 07, 2011
SOURCE: I have a Vx2433WM and am using it as a tv for my
I'd check in the control panel under sounds and see what the system thinks the output device is. Probably not the speakers. If not, change the output to your computer speakers.
I have a Samsung LW32A33W and it worked fine using HDMI cable for connecting a PS3. Suddenly when I connect my PS3 with the TV using the same cable I get a blue screen and nothing happens. Any ideas?
That HDMI connection hub port it some how got short and it dead.Tries other HDMI connections hubs.If all are like that they are all dead.All HDMI hubs ports connections are link together.If one dies usually all HDMI hubs dies together.Than ur tv Tuner signal board will not have anymore HDMI hubs functions connections at all,none of the HDMI hubs will work again ever.Have happen to mine Samung tv,so now i have to stop using HDMI hubs all together.
1helpful
3answers
All of a sudden, no sound on PS3, great pic though. Using HDMI cable...have checked all connections, reset PS3, etc. Still no sound! Guy from Sony said my HDMI cable(Monster) could be bad?! No sound, but...
I agree with the guy from Sony, the reason for this is the HDMI cable should support the transfer of audio and video over the same cable, if your only getting video over it, the cable could be defective, or its possible that you have another cable in the spot where speakers should go that is over riding the HDMI.
What exactly is the HDMI cable plugged into? Is it direct from TV to PS3?
If you have a stereo set lying around that supports HDMI - try having it run through that.
Is the TV muted? check if you can get sound while watching normal TV channels.
Worst comes to worst, use RCA Plugs remembering that the composite video is (yellow) and stereo audio is (white and red). You don't need to connect the composite video, but connect the stereo audio.
If this did not solve the problem, please leave a comment and I'll get back to you once I can =)
PS3 no longer communicating with TV
The problem is with your PS3 itself.
If it's still under warranty, take it back.
2answers
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
5helpful
4answers
Ps and TV not connecting using av cable
when you turn on the ps3 hold the power button till the system beeps
HDMi Slot has stopped working
Your TV settings are they set to the HDMI port you are trying to use?
Ps3 hdmi connection
Have you tried to select the source on the tv? If not try this. This will select the ps3
3answers
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
