20 Most Recent
ViewSonic VX2433WM 23.6" Monitor Questions & Answers
Screen cuts off image
To see the button on the right hand side of this monitor you will need to shine a really bright light on it, but the buttons from top to bottom are: 1, up-arrrow, down-arrow, and 2.
- On the side of the monitor press the 1 button to activate the menu.
- A configuration menu for the monitor will appear; from that menu highlight the "Input Select" menu item using the up and down buttons on the monitor; when you have the item high-lighted, press the 2 key.
- A new menu will appear, and then you can select the menu item called HDMI on the left and PC waaay over on the right. Select this menu item with the up and down arrows and when it is selected,
- And press 2 like you did in the previous step.
Apparently there's some sort of a strange difference between using this monitor as a "video monitor" and using it with a computer.
11/13/2014 3:46:58 AM •
ViewSonic...
Answered
on Nov 13, 2014
Dead on arrival need to open back cover
emtv_satc852, First visit YOUTUBE and watch some of them being pried apart at their perimeters around the four edges. That's how most of them are opened. Some people use an old CD or DVD disk, while some use thin blade screwdrivers. Try "lcd monitor disassembly" or "lcd monitor repair" on YOUTUBE. Good luck. Hope this helped. 12fixlouie
11/13/2014 3:43:51 AM •
ViewSonic...
Answered
on Nov 13, 2014
I have a Vx2433WM and am using it as a tv for my
Hi,Welcome to Fixya. If the volume is not working on the monitor the next thing you need to check is the HDMI cable. If possible to replace the cable so that we can determine the problem if this is caused by the cable, the monitor or the PS3. You can also try to connect the PS3 to a different TV using the same cable and see if you will hear a sound. Please let me know what happen so that we can continue troubleshooting.Thanks
11/13/2014 3:39:38 AM •
ViewSonic...
Answered
on Nov 13, 2014
I hooked up a vx2433wm monitor to a dell computer,
this monitor has a separate audio in cable that must be connected on the green audio in socket at the back of your computer to the back of your monitor. this is usually a thinner cable as compared the the thick cable which goes to the video card for video.
11/13/2014 3:33:24 AM •
ViewSonic...
Answered
on Nov 13, 2014
The sound cut out completely.
And this is the sound coming from the monitor itself, you have a VX2433WM monitor, correct? I have seen these internal speakers go bad many times. How old is this monitor? It may still be covered under warranty.
Please let me know and I can help you further, just confirm those things for me. Just reply to my answer here and I will be right back with you.
Thanks,
Tim
11/2/2010 11:52:11 PM •
ViewSonic...
Answered
on Nov 02, 2010
Viewsonic VX2835wm monitor that powers up with a good screen for a couple of seconds and then goes blank. I replaced the power board and it still does the same thing. Could it be the on/off switch?
FIRST WE DO NORMAL AND LATER TRUE CAUSE.
gee that is normal on all monitors and by Energy Star laws too.
the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days.
and the OSD button goes dead after. that. too. fooling the untrained.
here is the first tests, NO PC connected at all
power on see power light glow correct color
then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works.
if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok.
this monitor is very very old, 2004?
it has CCFL back lamps not LED<
and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now.
this is what they do: all do , used fully.
1: goEs dead forever, (vast did)
2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD.
3: DIM BULBS (like me. lol)
4 TURN YELLOW FOR WHITE screens.
5: STROBEs. (FLASHes)
AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
3/2/2022 5:23:35 PM •
ViewSonic...
Answered
on Mar 02, 2022
Viewsonic VX2880ML 4K monitor, front vontrols won't work, help.
power on and power on led glows normal , not yellow or flash.
then this happens splash. attached, 2014 made.
then that tells you screen is NOT DEAD is it? now? here?
(PC is dead or missing)
- NO connections on 1 or more inputs.
- NO sync
- no signal
- OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad.
if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused.
3/2/2022 4:55:16 PM •
ViewSonic...
Answered
on Mar 02, 2022
My new Viewsonic VX monitor shows "no signal" when connected to computer.
that means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
3/2/2022 4:54:28 PM •
ViewSonic...
Answered
on Mar 02, 2022
Screen won't come on, on my Viewsonic VSR220
WHY DOES THIS SEARCH SHOW.The Viewsonic VSR220 no such thing.?Turn the monitor around, 180 and see the TAG sticker with real model toldno PC told , what PC is this?this ? VSD (D key is next to R) so huge typo"?https://www.viewsonic.com/eu/products/lcd/VSD220yes that is a PC (android)but can do monitor like duty. too.it needs service.if screen is dead, it has power problemsas the screen must at least show a viewsonic splash as power is turned on.try it on a 2nd room AC power jack yet:?if in warranty take it back to the storeor call viewsonic for help.the android PC can use an HDMI cable to a PC and works as a monitor.too.the manual states"4.5 Connecting to HDMI-compliant Devices via MicroHDMI InputHDMI (High-Definition Multimedia Interface) is a compact audio/videointerface for transferring uncompressed digital audio/video data. You canobtain the best user experience for video playback and gaming via HDMI.VSD220 is equiped with a micro HDMI input for connection to an externalHDMI-compliant device. You can connect your PC, notebook, Blu-ray playeror any other HDMI-compliant device to VSD220 for high-definition videodisplay."
2/16/2022 7:47:31 PM •
ViewSonic...
Answered
on Feb 16, 2022
