ViewSonic VX900 19" LCD Monitor
Take a brief Survey Take a brief Survey   Add to My Products Add
Problems with ViewSonic VX900 19" LCD Monitor?
Troubleshooting and Support
Solved Problems for ViewSonic VX900 19" LCD Monitor RSS Feed Post a New Problem
Can you give me a hint how to take apart a...
Since you've done it, can you describe the procedure ? THanks in advance.
2 Solutions
vx710
My screen is blinking off. It shows a picture for about one second and goes black. This is constant.
2 Solutions
screen resolution not clear when photo put...
when I place a photograph onto the screen, it always appears too large and quite fuzzy. It chops heads off at the top!...
1 Solution
LOOSE CABLE IN FRONT AREA OF MONITOR
My father shipped me a 19" View Sonic - when I unpacked it there was a round cable wire with prongs that had come...
1 Solution
Viewsonic VA912b black screen no ghost...
You mentioned suface mount fuses on inverter  board: where and where? Also, how? and where do I get the fuses?...
2 Solutions
VX900
POWER LITE COMES ON WHEN MONITOR IS PLUGGED IN, BUT IT BLINKS ( ABOUT 4 PER SEC ) AND IS ORANGE -- THE POWER SUPPLY...
1 Solution
vx900 dispays for a second and goes blank.
What does the 100uf capacitor look like? Is it labled on the board or the capaciter itself. I have one guess. It is a...
1 Solution
Unsolved Support Problems
Unsolved Problems for ViewSonic VX900 19" LCD Monitor RSS Feed Post a New Problem
LCD MONITOR NOT MOVING FARWARD STOPS ONLY...
after pluging it stops on white window. is it must to install driver for a lcd monitor . i have viewsonic lcd monitor
Post a Solution
lcd monitor
alread think is show red
Post a Solution
fuses
hi i was reading this post: http://www.fixya.com/support/t282636-blown_fuse_value and noticed in the comments that you...
Post a Solution
Any help Yellow light only
Once plugged in the yelllow light is alll that i get. I can see the back lights on when the cover is off. thanks
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
Aspect Ratio4:3
Size19"
Color Depth24-bit (16.7M colors)
Contrast Ratio600:1
Brightness250 cd/m
Max. Resolution1280 x 1024
Dot Pitch0.29 mm · .29 mm
Monitor TypeFlat Panel LCD TFT (Active Matrix)
Response Time25 ms
Viewable Picture Size19 in.
Technical Features
Form FactorDesktop
Audio OutputSpeaker(s)
Audio InputStereo Mini-Connector
Regulatory ApprovalBSMI · CE · UL · cUL · FCC Class B · C-Tick · Nemko · CB · TUV-GS · DOC-B · TUV-S · ISO 13406-2 (Pixel defect guidelines) · Energy star · TCO-99 · SEMKO · TUV-ERGO · PSB · MPR-II · GOST-R · DEMKO · FIMKO · PCBC
Digital Video Input StandardDigital Visual Interface (DVI)
Synchronization Range - Horizontal30 - 82 kHz
Max. Viewing Angle - Horizontal170
Max. Viewing Angle - Vertical170
Native (Recommended) Resolution1280 x 1024
Resolutions supported1280 x 1024 · 800 x 600 · 640 x 480 · 1024 x 768 · 832 x 624
Synchronization Range - Vertical50 - 75 Hz
Dimensions
Depth7.13 in.
Height18.72 in.
Width17.41 in.
Weight16.76 lb.
Warranty
Warranty3 Years
Supported Models
Black, Metallic, Black, Silver
ViewSonic Contact Information
Main support number(800) 688-6688
Support FAX(909) 468-1202
Email supportservice.us@viewsonic.com
Sponsored Links
Loading problems.
Top Monitor Experts
Fix-4U
14 solutions
Monitors
Ask Me
Guru
bammbamm
7 solutions
Monitors
Ask Me
Guru
jerryg50
2 solutions
TV and Video, Cameras and Photography, Home Audio...
Ask Me
Wiz
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
