If there is no power check the adapter, if there is power then remove and keep aside so as to reset. If the unit does not switch it is possible that it needs a reboot. To reboot L+R+start or hold the power button on till the
psp resets If this wont work please contact the dealer
If the iPad will not reboot using the standard "Hard Reboot" (holding the power button and home button until the iPad restarts.) then I would advise restoring the iPad using iTunes which will set it back to factory settings.
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. [email protected].
so i can give you one on one technical support.
You may need to press and hold the sleep button. If not try to treat it like an ipod. Hold the center button at the bottom and the top one at the same time. Should reboot.
