20 Most Recent Apple iPod MP3 Player Questions & Answers
well, I've yet to see this problem but
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. Good luck.
Apple iPod MP3... | Answered on Jan 27, 2018
Hi
If you go to the Apple site in the link you can restore to the original versions of iPod software, in other words downgrade.
iPod Reset Utility 1.0.3 for Mac
Use iPod Reset Utility to restore the following iPod models back to their factory settings.
Mar 24, 2008
Download
What you should be doing though is upgrading the firmware for the Honda system.
https://support.apple.com/downloads/ipod
Apple iPod MP3... | Answered on Apr 27, 2017
The only way to solve this problem is if you use this free software to remove the DRM protection. http://all-streaming-media.com/remove-DRM-protection/ Hope this helps...
Apple iPod MP3... | Answered on May 06, 2015
Tip
Code?! FORGOT YOUR CODE?!
In order to get rid of the forgotten code and disabled message, we must restore the device.
In this case when the iphone or itouch or similar is giving you a message that its disabled, then we have to first force the device into recovery mode, from which we can do a normal restore.
Note that this removes all the content from your player.
Basically the steps are
1. Take out the usb cable, connect it to the computer, but not to the device.
2. Turn off your device
3. While pressing and holding the home button, reconnect the usb cable to the device, when you reconnect the usb cable the phone or itouch should power on.
If you are low on battery let it charge for a while, then start from thebeginning (unplug the usb from the device)
4. While still holding the home button, until you see a message about "Connect to Itunes" then let go.
5. if not already open, open itunes, you should receive a short warning about recovery mode.
6. do a normal restore from itunes, it wipes the devices and the disabled message and the forgotten code are removed.
on May 01, 2014 | Apple iPod MP3 Player
plug in ur ipod to the computer then go to the start menu then go to control panel.then click on apperance, after that u should see alot of options but u need to click on the option that says folder options. then the window that pops up from that there will be tabs at the top u need to click on the one that says view. then go down to where it says hidden files and folders and click on the one that says that u want to show them. then click apply at the bottom corner. then go into my computer and click on the ipod icon then there shouuld be a folder that says locked folder click on it then in the next window just rename the files as _unlocked then u should be able to disconnect your ipod and be able to jam out.... it worked for my 120 gb ipod
Apple iPod MP3... | Answered on Apr 22, 2014
chek your charger port if good replace your battery
Apple iPod MP3... | Answered on Feb 15, 2014
Have you tried restoring the iPod? Keep in mind that doing this will erase all the music and files from your iPod so make sure you have them backed up on your computer. Step-by-step instructions on how to do this can be found in the Apple document below.
One or more files may have become corrupt and just need to simply be replace, so restoring it may be able to do the trick. Hope it helps.
Apple iPod MP3... | Answered on Jan 01, 2014
Place two fingers on the screen and rotate them either clockwise or counterclockwise to rotate the iPod's display.
From https://discussions.apple.com/message/19007049#19007049
Apple iPod MP3... | Answered on Dec 04, 2013
my friend sold me a ipod and the screen got locked and he forgot the password
Apple iPod MP3... | Answered on Nov 13, 2013
As a parent I share your concerns, however there seems to be no stopping these kind of images from showing up, unless there is a parental control option in your existing programs, todays websites are flooded with popups of lude images, even a simple cooking site had a **** link popup when I opened it. the best thing you can do is educate your children on the goings on and make them aware that a lot of the **** sites contain viruses and hacks that will delete and harm their ipods, they are tricks to lure you to open them and view more, so if they want to let hackers destroy their ipods thats what they can expect. Its hard to expose our babys to this kind of activity but education and understanding will keep them safe and make them smarter. I don't know if you share my ideas but I am glad that you show enough care to find different answers. take care and remember, we didn't come with a book of instructions for our kids, we do the best we can. Be well.
Apple iPod MP3... | Answered on Oct 15, 2013
replace the internal battery
Apple iPod MP3... | Answered on Sep 30, 2013
Try recharging your ipod for a lil while maybe the battery got weak, nod32 could also be blocking your device, i would suggest uninstalling nod32 and get avg free edition it is a lot better to use.
Apple iPod MP3... | Answered on Jul 19, 2013
If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector) ipodg1-2.gif ipodg3.gif
  2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Apple iPod MP3... | Answered on Jul 03, 2013
security code for Apple Ipod A1199
Apple iPod MP3... | Answered on Jan 20, 2013
Apple iPod MP3 Player Logo
Popular Tags
325 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
iPod Apple
  • iPod Apple
Most Popular Question
ipod a1059 stuck
  • Audio Players & Recorders
