20 Most Recent E-Machines W3107 (RBW3107) PC Desktop Questions & Answers
E machine w 3107 from the power supply where do the wires go? I need a power switch with wire?
ok do you have more info? its usually very simple. the main power from the PSU goes to the motherboard by a big connector .. this connector is the only one that fits the motherboard and the connector is usually in the middle of the motherboard
9/22/2014 5:15:15 PM • E-Machines W3107... • Answered on Sep 22, 2014
How to get past the insert disk #1 in system recovery on a emachine?
yes you can reset it ... tapping Esc key if it is in DOS
4/24/2014 8:35:24 AM • E-Machines W3107... • Answered on Apr 24, 2014
Cd-rw runs for 5 sec. and stop
Hello, Check your Cd-rw for bent pins or dirty connections. If its not that then you can try the drive in another computer (if you have one) and see if it works. If not then you probley need a new drive. Check www.newegg.com for new drives. Hope that helps.
2/3/2014 8:13:30 PM • E-Machines W3107... • Answered on Feb 03, 2014
I cannot find an audio driver for a Emachine w3107
Download Emachine w3107 Driver ..go to driverzone.com then download audio driver
12/25/2013 9:01:39 PM • E-Machines W3107... • Answered on Dec 25, 2013
No multimedia audio controller look for drive
If I understand, it seems that there is some issue with the sound driver, to resolve this, you need to visit your computer's manufacturer website for example, if you are using dell then visit dell.com or if hp then hp.com, then search for support and the click on driver downloads and look for audio drivers, download it and then install it and restart your computer.
Hope this would fix the issue.
12/25/2013 8:58:27 PM • E-Machines W3107... • Answered on Dec 25, 2013
Some and then no sound on smilebox
Re-install smilebox.
4/18/2013 9:28:22 PM • E-Machines W3107... • Answered on Apr 18, 2013
Will not boot up
Hello there and welcome to fixya Could you please tell me what kind of computer and what operating system you have so i can provide you with the best possiable solution ok'best regards mike
3/2/2013 1:24:41 AM • E-Machines W3107... • Answered on Mar 02, 2013
Fan runs fast and no bootup
An eMachines desktop or laptop computer fail to boot for a variety of reasons, but a fast, loud fan noise signifies that the system is suffering from overheating.
The problem, and the steps for troubleshooting it, is not unique to the eMachines brand. When the internal temperature of the computer reaches too high a level, the system will shut down automatically to allow the heat to dissipate.
If you attempt to power up too soon, the machine will not boot properly.
To boot, you will need to correct the cause of the overheating, and keep the machine cool.
Blocked Vents
Although different in size, both desktop and laptop computers have air vents to help the fans keep air circulating around the hot internal components.
If these vents become blocked, by pushing a desktop too near a wall or using the laptop on a soft surface, the air supply your internal fans need to cool the system is cut off.
This blockage also traps the heat inside, allowing it to build to dangerous levels.
Keep the air vents on your computer free and clear to allow proper airflow.
Dirty Computer
Airborne particles, such as dust, lint and hair, can gather on the air vents and internal components over the course of time.
This accumulation of dirt not only provides a sort of "insulation" to the electronic components, preventing the heat they generate from dissipating normally, but it also clogs the fan and heat sink to prevent proper function.
Use canned air and damp, soft cloths to thoroughly remove any built-up debris from inside your computer.
Dried Thermal Paste
The heat sink sits atop the CPU chip to help dissipate the heat the component produces. Thermal paste is layered between the CPU and the heat sink to help draw the heat away from the chip for cooling.
Over time, the cooling properties of this paste decreases, and the substance becomes dry and flaky.
You can replace this paste to renew its cooling assistance by removing the old paste remnants with rubbing alcohol and adding a new layer.
Thermal paste is also known as thermal compound or thermal grease, and is available at most electronics stores.
Hot Environment
When examining overheating causes, don't overlook the environment you use your computer in.
External heat sources, such as fireplaces or even rays of direct sunlight, can cause the internal temperatures of your computer to rise.
This causes your internal fan to run harder in an attempt to dissipate the combined heat before temperatures rise too high.
Move your computer away from external heat sources to encourage more effective cooling.
11/7/2012 8:42:39 PM • E-Machines W3107... • Answered on Nov 07, 2012
Elu tgs saw wont start up flip over
i have no clue what you're talking about If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
8/2/2012 5:36:38 PM • E-Machines W3107... • Answered on Aug 02, 2012
Emachine w3107 starts up just hear fan and nothing comes on the monitor
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps
7/13/2012 9:23:54 PM • E-Machines W3107... • Answered on Jul 13, 2012
Emachines comp will not boot up
hmm..ok try it while pressing F8 on power up to go to safe modelet me know how that works for you
5/23/2012 6:06:32 AM • E-Machines W3107... • Answered on May 23, 2012
Admin password
Depend on the operating system you are using. There is a program you can buy to retreive your pass word. Unless you know someone with that software or it depend on the operating system you now have.earlier windows can be retrieve much easier. Either way you will need to buy it.
3/25/2012 2:22:03 AM • E-Machines W3107... • Answered on Mar 25, 2012
My speakers work but my
Try right clicking on my computer and select manage. You can reach my computer in the start menu if it is not on your desktop.Then click on device manager.There will be a listing sounds and audio devices double click that and options should come up to scan for hardware changes update drivers.Choose to udate your drivers and it should prompt you to search the web for updated drivers. Once you have updated the drivers reboot the pc. Hope this helps.
3/14/2011 3:43:01 PM • E-Machines W3107... • Answered on Mar 14, 2011
Need video card for w3107 and also hard drive
This machine originally had a 100GB PATA (EIDE) hard drive. It should be able to take any size PATA drive currently available. If you install it and your system happens to have the old 137GB BIOS limitation, update the BIOS. If that doesn't work, you can buy a PCI hard drive card that will allow you to use the entire drive.
This machine has on-board nVidia GeForce 6100 video but it also has a PCI-express X16 slot for a dedicated video card which would improve video and system performance. Any PCI-e card will work but if you don't want to have to get a larger power supply, make to to get one that doesn't require more power than your system can handle.
This machine also comes with only 512MB of DDR PC3200 memory but it can be upgraded to as much as 2GB.
2/22/2011 2:39:02 AM • E-Machines W3107... • Answered on Feb 22, 2011
My emachine does not load
more then likely the DVD laser part of the drive has burned out, i have nearly the same model and had to replace mine a couple years ago!! This is a classic situation, the CDROM laser is still functional, but DVD is inop!!! New DVD-RW Drives about $20 on www.NewEgg.com and even cheaper on www.eBay.com for a decent DVD-ROM model!!! Easy fix too, just make sure you get the IDE style, or make even faster with SATA, if you have a SATA available on your system!!
2/20/2011 5:42:59 PM • E-Machines W3107... • Answered on Feb 20, 2011
I have no sound on
1.UNINSTALL AND INSTALL THE DRIVER
OR
2.U MIGTH HAVE ENABLED THE MUTE BUTTON IN SOUND OPTIONS.UNCHECK IT.
SETTINGS->CONTROL PANEL --> HARDWARE AND SOUND .WHERE YOU CAN UNCHECK THE SOUND OPTION
2/9/2011 5:42:23 AM • E-Machines W3107... • Answered on Feb 09, 2011
W3107 desktop pc microsoft office
I highly doubt anyone here will give you their key. If you want to use word, their is a free office suite known as Open Office. If you want the software, i suggest buying it, or asking a friend or family member.
12/30/2010 9:05:36 PM • E-Machines W3107... • Answered on Dec 30, 2010
Need to access backed up data from angel recovery
Restart computer keep hitting the " r " key will take you into recovery , do a destructive recovery , you will have to reinstall programs added since computer was new , if you dont show (d) can contact e-machines support @ (408) 273-0888 they will send you a recovery disk for $20.00 takes about 5-9 days.
12/30/2010 8:52:21 AM • E-Machines W3107... • Answered on Dec 30, 2010
My little sister put a
use this http://pogostick.net/~pnh/ntpasswd/ to remove the present password then put your own.
12/21/2010 9:36:59 AM • E-Machines W3107... • Answered on Dec 21, 2010
My sound was working fine
It could be feedback from your microphone. Place them further apart and see if that makes a difference. Otherwise, the sound card might be bad.
12/9/2010 2:31:52 AM • E-Machines W3107... • Answered on Dec 09, 2010
E-Machines W3107 (RBW3107) PC Desktop Logo
56 questions posted
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W E-Machines
  • W E-Machines
Most Popular Question
fan runs fast no bootup
  • Computers & Internet
