Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
SOURCE: When I turn on the camera it is showing "Card
Take a look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try a different card.
SOURCE: everytine I turn my camera on "The card is locked"
Remove memory card from the camera, look along the one edge you should see a small switch, slide it over to unlock the card. the farthest from the contact the switch is in the locked position to prevent deletion of pictures.
SOURCE: I keep getting "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Troubleshooting steps for this problem are listed here.
