Cooktops Logo
Posted on Sep 18, 2008
Gas stovetop burner - continuous clicking
Continuous clicking after the burner ignites.  Creda Gas Glass Stovetop
  • 2 more comments
  • kwjstudio Oct 26, 2008
    The electronic ignition on our new Jenn-Air cooktop lights the gas but continuously clicks.
  • bet4less Dec 07, 2008
    Please, help me with solution. My husband just resently pass away and I am lost.. My Km443 get out of control compleatly.. Sound signal Will not stop not by day or nihgt, unless I turn from electrisity compleatly. Thank-you for any help.Afraid to call professional, assuming it may cost fortune Bella
  • funnybuttrue Dec 15, 2008
    My stove top clicks none stop. It lights when gas is turned on but will not stop clicking when turned off or even once turned on. The only way to make it stop is to unplug unit. I have tried cleaning connections on all burners and also reajusting placement of iron top as was previously mentioned. help please.
  • canv1mom Apr 25, 2009
    All of a sudden out of nowhere the stovetop started clicking. All the burners lit but the clicking continued. I had to unplug it to get it to stop.
A
Anonymous
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
10helpful
Creda stovetop ignitors won't stop clicking
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
One front burner ignites but the igniters continue to spark. when all other burners ignite the igniters immediately stop sparking. this problem started right after spilling some water on burner.
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
Jun 06, 2010 • Cooktops
1helpful
Creda stovetop tries to light without gas on.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
2helpful
Stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
8helpful
2answers
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 • Cooktops
2helpful
Stovetop stays hot when burners are not on
Is it a glass top. If it is, glass will absorb the heat. It will cool off after some time. That is normal.
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
