20 Most Recent KitchenAid 30 in.KECD806 Electric Cooktop Questions & Answers
I have checked a number of sites and many of the gaskets or seals for this model are not available....
I would call a site like this one and see if they could recommend a functional replacement for you.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=238863&diagram_id=28248973#d28248973
heatman101
KitchenAid 30... | Answered on May 23, 2011
Contact KitchenAid directly and ask what the cutout size is for cooktop kecc508. They may be able to supply a template.
KitchenAid... | Answered on Nov 20, 2018
You need one with a smooth stainless steel or aluminium bottom. Don't use cast iron because it is rough. Or you could sit any on a round profile metal triangle. Here is a star shaped one
2 Pack Stove Ring Heat Diffuser Metal For Electric Gas Glass Stove Top...
KitchenAid... | Answered on Oct 02, 2017
They go under the counter and they are screwed in place
KitchenAid... | Answered on Feb 07, 2017
Need model number of your range to answer this question. Is this gas or electric? Is this a freestanding range or cooktop because I only can find information on ranges with this fault code given. All should EEPROM communication error which is a communication error on start up. when the top was damaged was the unit being used? Was water or liquid a factor when this damage happened? A loose wire would be a different error code or fault code like a F2 - E1 or E2, not your code given. I hope this helps, need more information. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
KitchenAid... | Answered on Apr 19, 2016
To Unlock Cooktop: Touch and hold the CONTROL LOCK/
ALL OFF keypad for 5 seconds.
KitchenAid... | Answered on Dec 06, 2015
changing everything on this kitchenaid cooktop video
KitchenAid... | Answered on Jun 27, 2015
Everything about It.. Thanks for watching
KitchenAid... | Answered on Mar 21, 2015
How I fix this problem! Thanks For Your time!
better get an electrician to fix it should not give you shocks ever
KitchenAid... | Answered on Feb 20, 2015
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
KitchenAid... | Answered on Nov 26, 2014
KitchenAid 30 in.KECD806 Electric Cooktop Logo
1 questions posted
Top KitchenAid Cooktops Experts
vince
freddyfox
Marvin
Marvin
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
View Most Popular
KitchenAid Cooktops
  • KitchenAid Cooktops
Most Popular Question
need gasket
  • Cooktops
