Kodak EasyShare M1093 IS Digital Camera Logo
Posted on Sep 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I TOOK PICTURES AND THE DATE WAS NOT SET CORRECTLY NOW THE STAMP ON THE PICTURE HAS THE WRONG DATE HOW DO I CORRECT IT ... I DO NOT WAS TO PRINT ANY OF THESE WITH WRONG DATES PLEASE PLEASE HELP!!!!
Piyal Perera
Level 3:
  • Master 528 Answers
  • Posted on Sep 19, 2011
Piyal Perera
Master
Level 3:
Answers
528
Questions
0
Helped
165625
Points
1520
You cannot change the dates on the taken photos using the camera.
Copy the pictures to your PC, and use a graphic editor to put the new date.
It is a very difficult task to change the date displayed. Therefore insert a button-like graphic on top of the date and put the correct date over that.
How can I set date time stamp on pictures........I have set it on camera, however its not stamping??
The camera stores the date and time (and a lot more) with each picture, but it won't deface your pictures by splashing numbers across them. If you want the date and/or time printed with your pictures, please refer to the documentation for whatever program you're using to print them. Depending on the program and the printer, you may have the option of printing the date stamp on the picture, in the margin, or on the back.
2helpful
2answers
When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
You haven't said what make/model your camera is, so it is hard to advise.
Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
Nov 03, 2010 • Cameras
1helpful
Purchased a Kodak easyshare M320 can not figure out how to set
You have two options for getting the date printed on your pictures. One is to set the appropriate option in whatever software you're using to print. The other is to have the camera put it there in the image itself. This means that if the date happens to cover something important, you won't be able to get it back.
To set the camera to put the date stamp on every picture, press Menu, use left/right to highlight Setup, then use up/down to access "Date Stamp".
DATE on kodak prints
I'm sorry it's not possible to add the date to the already taken picture on the camera. You could have it added in a software correction software.
In order to have the date and time on future pictures:
Menu
Camera Settings
Date Stamp (Icon is an old fashioned stamp)
Choose ON
1helpful
Printing pictures from Casio Exilim
To remove the date/time stamp from your photos, you will have to either crop (cut) it out or use a Photo editing program to remove the date. Good photo editing programs are Photoshop and Paint Shop Pro amoung others.
13helpful
2answers
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
[email protected]
1helpful
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
9helpful
2answers
TZ 5 not TZ50! Date stamp.
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or, view picture you want date & time stamped. Press the circular 'Menu/Set' button. Press down arrow to playback mode. Press right arrow on 'text stamp'. Choose whether to apply stamp to single or multiple photos. Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Date and time function
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
1helpful
Date stamp
Choose the Postcard Print mode option. Make sure the date is set correctly. Choose the Date Stamp option out of the menu. It should now stamp a date.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
