The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the scrrens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced
GENE
Error code fh ,,no water coming to unit for some reason,,,are both your hot and cold taps are turn on can the fill hose be kinked,,,do the unit drain ok if unit does not drain water timely the unit will not fill again than stall out,,with code...make sure your fill hose screen are clean if water comes in unit to slow it will cause error code fh,,,good luck and keep me posted...
