The drain hose is clogged/kinked, the drain filter/coin trap is blocked, or the drain pump is
broken. Replace the drain pump after
having found no problem with the drain hose, cleaned the filter, and
checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Remove the screws securing the top panel to the rear of the machine cabinet then slide the panel rearward and off.
Remove the screws securing the console to the inside of the cabinet.
Remove the dispenser drawer and remove the screws in tFrigidaire Front load washer ATF8000FS1 - jahn27_611.jpghown below.
Pull the bottom of the console forward while lifting up to rFrigidaire Front load washer ATF8000FS1 - jahn27_613.jpgtom tabs from the front panel. Rotate the console until the electrical connections are visible.
Disconnect the following wire harnesses from the console.
Disconnect the other console wire harnesses from the connections inside the machine cabinet.
Using
needle nose pliers, start where the spring and wire are connected at
the bottom of the bellows and pull the wire out of the groove of the
bellows then pull the bellows off of the lip of the front paFrigidaire Front load washer ATF8000FS1 - jahn27_619.jpg/>
Remove the screws
securing Frigidaire Front load washer ATF8000FS1 - jahn27_620.jpgand switch assembly to the fFrigidaire Front load washer ATF8000FS1 - jahn27_621.jpgce the
screws are removed, lift the door lock and switch assembly to release it from the front panel.
Remove the screws along the top edge of the front panel then the screws along the bottom edge.
Disconnect all wire harnesses then lift up and pull the front panel off the plastic retainers.
Loosen the clamp securing the pump's outlet hose and the tub-to-hose pump to the bottom of the tub then take the filter out and remove the debris. You should find foreign objects such as coins,
toothpicks, hairpins and the likes blocking the filter. Clear the
filtFrigidaire Front load washer ATF8000FS1 - jahn27_623.jpgn objects and inspect the pump impeller by turning
it with your finger. The impeller may be restricted or damaged
resulting in the water not pumped out properly. Replace the pump if
the impeller is broken or restricted and doesn't turn freely. Reassemble
the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
There might be a problem with the door lock/switch assembly if the machine still does not spin with the drain filter cleared and drain pump working. Click on the link below for more details.
Frigidaire Front Load Washing Machine Not Spinning
Please accept the solution
should you find it helpful and/or informative. Accepting the solution will not bar you from
posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
