SOURCE: I am having a problem
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
SOURCE: Not able to install any software on my PC having Windows XP
install windows instaler from here.
http://www.softwarepatch.com/windows/wininstallnt.html
SOURCE: eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
When you run the reset
command, it rewrites two registry keys that are used by TCP/IP. This
has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys:
SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
SOURCE: Windows Xp activation
If you don't enter the product key within a certain period after installing, Windows XP will expire, and will cease to function .
Check this out. If this does not help, then call microsoft , they will do it for you.You'll have to activate Windows XP again. However, since all your hardware is the same, Microsoft will simply re-issue you the same key.
http://support.microsoft.com/kb/307890
SOURCE: iTunes ''not responding'' using VISTA 64-bit
are you running itunes 64 bit? that would be your solution there. download the 64 bit version and it'll solve all your problems.
Key features like what you can do with it. Requirements:
Samsung PC Studio application was designed to be a professional tool that you can use to manage you personal data and multimedia files by connecting a Samsung Mobile Phone.
Note: To use PC Studio multimedia functions such as MMS Composer, DirectX v9 or higher is required
Connection manager:
• Allows you to select the connection type for PC to Phone connection.
• The connection types: USB, Bluetooth, Infrared or Serial.
Manage messages:
• Manage short messages and multimedia messages.
Manage contacts and more:
• Allows you to retrieve personal information saved in the Phone, such as phonebook and organizer and to add new data or delete and edit the saved data.
Synchronize:
• Allows you to synchronize personal information data saved in the Phone and the data saved in the PC's personal information management program.
Transfer files:
• Allows you to browse multimedia files saved in the Phone in the windows browser and to download files or to upload PC files to the Phone.
Manage internet connections:
• Allows you to access the Internet using the connected Phone as a modem device.
Compose multimedia messages:
• Compose your own multimedia message and send through your phone.
Drag & Drop:
• All the selected contents can be easily transferred among widgets and icons on the screen by Drag & Drop
Easy Start:
• Easy Start runs automatically when a mobile phone is connected to New PC Studio.
• It helps you step-by-step transfer or synchronize content among PC and mobile phone.
Update music information:
• Update various music information like artist, genre, Review and etc. on Media Manager widget.
Share content on the web site (To Web):
• Post content of photos and videos to the web sites such as Flickr and YouTube by Drag&Drop.
• CPU : Pentium 600 MHz processor or higher (recommended)
• Minimum memory(RAM)size : 512MB
• Free hard drive space : 200MB
• Connection methods : USB cable or Bluetooth
According to your mobile handset model have two features to connect with PC.
Install Samsung PC studio software (Downloadable from website) in your PC.
Connect your handset with PC through USB data cable and wait for detection.
Go to the Phone settings in your handset then open the PC connection wizard and select Samsung PC studio option.
Now open the software access your mobile or transfer your data. Net access is also possible through this way after activating GPRS.
Here have another way to transfer data. Your Handset have Bluetooth facility.
Activate your Bluetooth from your hand set.
Use a Bluetooth dongle in your PC and install it
