2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio.
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link) 2. Connect Your Samsung with a working Internet connection ( via )USB Cable3. Samsung PC Studio or any other Samsung mobile drivers are not installedProcedure1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.2. Goto Control Panel > Phone and Modem Options3. Select the Modems tab. You will see Samsung mobile modem listed.4. Select it and click on Properties.5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:+cgdcont=1,"IP","your_apn_name" ( or tye AT+CGDCONT=1, "IP', "apnname") eg:- +cgdcont=1, "IP", "bsnlnet"6. Hit OK and exit.The next step is to create a dialler for your Samsung Star 3G mobile modem.Error 619 solved1. To create a dialler, Goto Control Panel>Network Connections2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):2.1 Network Connection Type: Connect to the Internet2.2 How do you want to connect to the Internet: Set up my connection manually2.3 Select Connect using a dial-up modem2.4 Select Modem-Samsung Mobile Modem2.5 Type an ISP name according to your preference (could be anything) 2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )2.7 Leave Username, Password and Confirm Password fields blank2.8 Hit FinishThat would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
242 questions posted
736 Questions
430 Questions
332 Questions
330 Questions
306 Questions
