HI SIR..
IT IS A CARD PROBLEM......FOR MORE GO TO.
This article provides instruction on the installation of the AirPort
Wireless Networking card into a Power Mac G4 (AGP Graphics) computer.
Similar instructions, with graphics, are included with the AirPort
card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer
to discharge static electricity. Avoid walking around until you have
finished installing the card. Unplug the power cord then lift the latch
on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the
AirPort card. The cable is usually stowed on the side of the PCI card
guide.
5. Remove the metal clip and pull the AirPort card from the
adapter card, shown below. The adapter card and clip are not used with
your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the
opening in the PCI card guide, and into the connector on the main logic
board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees
may apply) and AirPort (or AirPort-compatible) wireless Ethernet card
and base station. Some ISPs are not compatible with AirPort. For more
information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
It may be network problem or router setting problem
To password-protect your wireless network:
Open
AirPort Utility, located in the Utilities folder in the Applications
folder on a computer using Mac OS X, and in Start > All Programs
> AirPort on a computer using Windows. Select your base station, and then choose Manual Setup from the Base Station menu. Enter the base station password if necessary.
Click AirPort in the toolbar, and then click Wireless.
Choose a password scheme from the Wireless Security pop-up menu.
Enter the password all users will need in order to join this wireless network.
Hi
So you need help to access your neighbour network... ;)
Yeah the problem is because you are accessing from MAC...
Here this link will ell u the exact solution..
http://forums.macosxhints.com/archive/index.php/t-68764.html
you try adding a $ (dollar sign) before the password? I was having the same problem with my work's wireless network, and when our admin suggested doing that, I was able to connect.
So if the password for your Windows compatriots is asdfg, the password your would enter is $asdfg
Let me know if you tried.. :):)
Check the type of security used on the G4 (WEP/WPA).
Check your router/base station for other type of security implemented (MAC address filter/restrictions).
For answers to all your Power Macintosh G4 questions, please check out the Power Macintosh G4 Q&A and Power Macintosh G4 Cube Q&A.
For troubleshooting assistance, please also review the support pages for the Power Mac G4 (PCI/AGP), Power Mac G4 (Gigabit Ethernet/Digital Audio), Power Mac G4 (Quicksilver), Power Mac G4 (Mirrored Drive Doors/Firewire 800), and Power Mac G4 Cube.
You sould be able to fix it this way.
Regards..
Wouter.
It was not p;rotected, u cannot gain connection coz the security was blocking or prohibit u to connect
