SOURCE: no images
Look in Explorer at the .jpg files on your card to make sure they have information in each file. Next, make sure your software is set to view .jpg files,i.e. Faststone Image viewer (download.com) can be set for virtually any image format. If you viewed the images on the lcd monitor they were on the card at that time. Make sure you haven't somehow protected those image files or have accidentally reformatted it.
SOURCE: i took some pics on
This is because camera will show these pictures with specific file name/ number.
You need to check camera taken picture file name/ number and change uploaded file name/ numbers as camera firmware generate it.
Please change picture file name according to camera taken picture.
let me know if further help required.
SOURCE: Tre problem is that my Mac doesn't recognize the
You could always use a card reader and download to a folder you create on your desktop.
SOURCE: After upgrading to MAC OS
Hi Bob.
Problem is a well known issue between Snow Leopard and several cameras. You will need to play with installed software and setting. Here different work around.
Temprarily turn Bluetooth off. See here.
Try installing the following: Adobe - Adobe Camera Raw and DNG Converter
If that does not work, try setting the Mac with camera mass storage in USB mode, I quote a testimonial from this forum:
"I found a workaround/solution for my issue. My camera has two USB modes:
"Mass Storage (USB DIRECT-PRINT)" and "PTP (PictBridge)". I've always
used PTP with my mac and everything has been fine. But apparently
iPhoto on OSX 10.6 no longer likes PTP (keep in mind that Image Capture
handles the camera fine in PTP mode). When I switched it to Mass
Storage mode, it works fine now in iPhoto."
If still no luck, change preference to image capture, I quote:
"1) ejecting the "camera name" from the desktop. I had to do this step
because I had tried to connect to iPhoto and it didn't work.
2) Going to iPhoto prefs and selecting Connecting camera opens "Image Capture" - not iPhoto.
3) Connecting the camera again. Image Capture opens.
4) In image capture selecting from the bottom left hand corner Connecting camera opens "iPhoto"
5) iPhoto magically opened and I could import and delete."
If still no luck, do a new upgrade using a combo installer, see here.
If all that does not work, contact Apple, camera is supported by Snow Leopard and they must find a solution. See: Apple - How to Contact Us.
Ensure that you try all workaround, there is no "one for all Macs" solution for this problem.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Good luck.
Ginko.
SOURCE: Don't know how to get
You can move the pics to your computer first, as for some camera, if you insert a SD card, you won't find the pics on the camera hard memory.
